Sponge Posted April 11, 2015 Report Share Posted April 11, 2015 I'd like to put a 15mm M10 axle on my front Pro 2 so I can run 10mm bolts, and was wondering if Euan still makes these and how much he charges? Alternatively, can anyone vouch for an experienced machinist who's able to make a 7075-T6 axle to a high tolerance? (I had one made by a machinist in the US, but the machining and tolerance was sloppy) Any help is appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
Dman Posted April 11, 2015 Report Share Posted April 11, 2015 I had one off him, pretty good really, only let down was no serrated washers like the hope ones, easily solved using hope washers, mine moved a bit without them. Quote Link to comment Share on other sites More sharing options...
bing Posted April 11, 2015 Report Share Posted April 11, 2015 All you need is a piece of 15mm aloy bar 99mm in length, with an m10 threaded hole either end and drill your pro 2 end caps to suit. Easy as that 1 Quote Link to comment Share on other sites More sharing options...
Sponge Posted April 11, 2015 Author Report Share Posted April 11, 2015 It's a simple bit of kit I know but having a slightly undersized (hence wobbly ) custom axle with threaded holes that sit at an angle just makes me all the more keen to get one that's done just right. The guy made it on Valentines day and he did it for cheap, so I can't complain. Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 11, 2015 Report Share Posted April 11, 2015 Alex Dark is your man! Quote Link to comment Share on other sites More sharing options...
John Shrewsbury Posted April 11, 2015 Report Share Posted April 11, 2015 I've been running one of Euan's axle's for afew years and it is a great piece of work. Think he charges about £25-£30 for one. Just look him up on Fb and he'll sort u out. Quote Link to comment Share on other sites More sharing options...
jonny.sl Posted April 12, 2015 Report Share Posted April 12, 2015 Would defiantly recommend a Euan Beaden axle, I have been running mine for nearly 2 years now and it's brilliant, can't fault it! Quote Link to comment Share on other sites More sharing options...
