Interesting/ alternate camera angles for filming?
Herbertlemon102
Having the standard angles for filming is all fine and well, but I like to throw some interesting ones in there, for example, holding the camera focused on the rider (who's about to do a drop) and jumping down at the same time.
One i found recently (link below) mounting the camera to the frame facing backwards, looks great for 'whips and manuals through puddles, even though there's none right now! :D
FWIW, the rear looking camera does offer a different than most perspective. The video you got is cool, but tough to really see the full action of some moves.
A few years ago, we set up the camera aft facing on the Ventana mountain tandem. I was not sure what it would be like or capture. When we viewed the recording, it was kind of cool to see the bike sliding a bit through corners, The shock and suspension linkage working it's butt off. Some roost coming off the tire and so forth.
Overall though, I found the rear looking setup best for capturing video of riders behind you. It does get boring after a bit.
I have done a couple of videos capturing simultaneous forward and aft footage. Those can be cool, again in more of a group ride setting. I should have done these as a split screen, but two different model cameras made it not work.
Honestly though, it seems the best videos are a mix of footage captured away from the bike, some helmet cam video, some frame video, and a bit of effort to give a good edit. This takes time and can be a pain if you are not into that kind of stuff.
PK
  • Like 1
