Mag help
harlequin
Hey all.
I recently acquired a newish Blade (12 model) but the previous owner sprayed the tyres with tyre polish which has gone over all the brake system and rim. In turn this has created a pretty greasy rim which, although thoroughly cleaned is still not providing any grip (Mag Hs11's). I can feel that there is plenty of pressure when the lever is pulled but the rim still slips through. Are the pads contaminated and time for new ones?
If they're the standard pads that came on the Blade, they're not particularly great - you'll notice a massive improvement if you switch to some trials-specific pads (Y)
are they the clear pads? if so, i remember them ebing quite good on a decent grind, they just didnt last long :giggle:
I seem to remember as standard the Blade just came with either black or red Magura pads rather than upgraded ones. I can't remember if TartyBikes did the pad upgrade on them or not though - if they did, that would be the clear pads (Y)
I am happier with my yellows in plastic backings than my adm's in metal backings (just saying)
At some point I also had a pair of unknown green pads that were just as good as the yellow heatsinks. They look the same as the rockman pands on tartybikes website but I can't say for sure.. not lgm's, it was something else!
Everybody knows for themselves, but I'd also suggest using average amount of tar on your rims which will help a lot!
Edited by naset000kzk
If they were the ones I sent you they were rockman greens
