Cleaning up Try-All Karbons
SamKidney
I'm pretty sure these forks have a normal gel coat on them and no clear coat as such. You can even out the scratches using sand paper (600, then 1000) and then polish them out. Spraying a clear coat on the forks might work in the short run but I'd expect flaking to occur sooner or later.
I thought you only gel coat fiberglass/carbon fiber?
Surely you only clear coat to protect paint?
