saracenrobb Posted March 21, 2015 Report Share Posted March 21, 2015 I am running a rear racingline rim brake and it's come time to give it a fresh bleed (with water), I bleed it fine (like I've done before) but the "plunger" inside the lever body won't return... What could be the problem ? Quote Link to comment Share on other sites More sharing options...
Ónodi István Posted March 21, 2015 Report Share Posted March 21, 2015 It needs lubrication, you can use royal blood for it, but I found out that silicone oil is much better, I mean it lubricates the o ring much longer than other oils. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 21, 2015 Report Share Posted March 21, 2015 I use a Silicone based lube for car window seals from halfreuds in mine. Has kept it buttery with water since Xmas 2013 (only reapplying it at the end of last year for peace of mind whilst there was no bleed in the brake). Ditto my MTB forks for longer than that. Silicone really is the only stuff to use. The bore on my early model single bolt clamp racingline is still the same as the day it went on, the black anodising is completely unmarked or tarnished. The packaging has changed but this has got to be the same stuff I use. Rig up a way to blow out the piston with a track pump and get both the piston & bore smothered int stuff. Pop the piston back in a bleed away. Quote Link to comment Share on other sites More sharing options...
saracenrobb Posted March 22, 2015 Author Report Share Posted March 22, 2015 Update* tried to bleed with proper mineral oil to no luck, May get trials addict to sort. Or I'll sell and buy a different brake. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 22, 2015 Report Share Posted March 22, 2015 (edited) Get that silicone spray!! I've used a smear of vaseline in the past too but ONLY if you're using the standard magura piston. Racing line pistons can only be used with silicone lube like that I linked because of the type of O-rings used. Give the spring a stretch as well. Beyond that, you can lead a horse to water... EDIT: You know what, If you do sell up, I want dibs on it. I put money I'll make that brake a proper sorted piece of kit and it will run forever and ever. The 05 magura master my racing line replaced lasted for seven years in near constant use with little more than knocking the plastic TPA ball back straight once when it skipped a thread and a very occasional wipe and vaseline piston service. Edited March 22, 2015 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
saracenrobb Posted March 29, 2015 Author Report Share Posted March 29, 2015 Brake is now for sale. (Plunger problem sorted). Currently £169 on tartybikes but out of stock. Needs new bleed screws with washers and a good bleed. Sensible offers. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 7, 2015 Report Share Posted April 7, 2015 Sorry to bump the thread, didn't deem it necessary to open a new one My Racinglines feel a bit lazy compared tot the others I've felt, does this silicone lube really help? Quote Link to comment Share on other sites More sharing options...
gage-mann Posted April 7, 2015 Report Share Posted April 7, 2015 Yea it's a massive help pal worth the buy when running alloy Pistons Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted April 7, 2015 Report Share Posted April 7, 2015 (edited) Sorry to bump the thread, didn't deem it necessary to open a new one My Racinglines feel a bit lazy compared tot the others I've felt, does this silicone lube really help? Oh yes. The difference is night and day. Edited April 7, 2015 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
