Onza problem
donski
I've broken a few of the Onza square taper BBs in the past - to unintentionally quote Tom Jones, it's not unusual.
If you've got the money to do so, it might be worth taking the opportunity to upgrade to an ISIS crank setup. It's stiffer and stronger so might be a good time to give it a pop.
Has it hard a lot of use? All parts do eventually wear out or brake.
Check this out http://www.trashzen.com/trash.php
Hi ,its not had hard use just the normal ,I do understand stuff does break but you do get a friggin fright whn it goes though !!
Hi ,thnx yeh I will hve a look at ISIS cheers
