What pads for K2 rims?
dann2707
I've currently got cousts at the moment and they're honestly shocking with the K2 rims.
I put a new grind on yesterday and it just slips and is nothing like the ADMS I had with my Echo urban
What pads are people using with K2 rims?
Thanks
Yeah i'll try and swap the fronts with the back to see if that changes anything as it's cousts all around!
They're hitting the rim absolutely spot on, ground the rim and cleaned the disc with wirewool to remove the alu clogging which dulls the grind so it's a spot on grind. Weird!
Maybe they're just contaminated.
