Pinned steerer tube replacement
Mikee
Extend the current one, it is very easy to do. You just need a tube to fit inside the current steerer and some spare steerer from another fork. Drill holes in each piece of steerer and taper the ends being joined and plug weld them togther, then seam weld the joint carefully grinding/filing the excess weld away. I've done quite a few forks this way for people with no issues
Do you have pictures of any you have done. I'm really quite keen to get these forks to a usable condition as they are getting pretty hard to come by these days.
