niconj Posted February 7, 2015 Report Share Posted February 7, 2015 (edited) Kinda pissed by this. My Try All Carbon forks are too narrow. I can't get my front rim to fit through the brake without at least taking away half the pad. Is that normal with these forks? By the way... the closed Racing Line Warning Thread... I just tried bleeding my new Nano lever and it's got the same issue. Poor quality on both parts. Edited February 8, 2015 by niconj Quote Link to comment Share on other sites More sharing options...
dave33 Posted February 8, 2015 Report Share Posted February 8, 2015 Yes the mounts are narrow. Designed with the narrow 28h try all hole rim in mind Which is 32mm I think Quote Link to comment Share on other sites More sharing options...
gage-mann Posted February 8, 2015 Report Share Posted February 8, 2015 Should of found out the spacing before buying them then! Ptfe tape will sort out your bleed bolt though Quote Link to comment Share on other sites More sharing options...
niconj Posted February 8, 2015 Author Report Share Posted February 8, 2015 (edited) Should of found out the spacing before buying them then! Ptfe tape will sort out your bleed bolt though One would think that a Trials specific fork works with a trial specific rim that is, surprise surprise, wider than a normal MTB rim. It doesn't say that it's only for 32mm rims in the description which it should! Would them TENSILE offset mounts work with these forks? Better than getting a different rim. With Aluminium washers it should work as well as with the washer less clamps I've got. Edited February 8, 2015 by niconj Quote Link to comment Share on other sites More sharing options...
gage-mann Posted February 8, 2015 Report Share Posted February 8, 2015 Yea that'd be the best, cheapest solution 1 Quote Link to comment Share on other sites More sharing options...
niconj Posted February 8, 2015 Author Report Share Posted February 8, 2015 Yea that'd be the best, cheapest solution Cool... because I really like them Trialtech SL Rims on the front. Just hoping that these Tensile clamps don't deform being clamped off center by the bolts. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 8, 2015 Report Share Posted February 8, 2015 Personally I would trim the pads down. Quote Link to comment Share on other sites More sharing options...
niconj Posted February 8, 2015 Author Report Share Posted February 8, 2015 Personally I would trim the pads down. I'd have to trim them down to about 3 mm to have enough clearance. As it is now, the pads touch the rim being half worn and w/o having screwed in the lever reach screw. So those Tensile mounts aren't good enough? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted February 9, 2015 Report Share Posted February 9, 2015 Tensile mounts have always been shite for me +1 on trimming pads down Quote Link to comment Share on other sites More sharing options...
niconj Posted February 9, 2015 Author Report Share Posted February 9, 2015 Tensile mounts have always been shite for me +1 on trimming pads down Trimmed the pads down. Are now at 3mm which kinda sucks. Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 9, 2015 Report Share Posted February 9, 2015 What pads are they? Quote Link to comment Share on other sites More sharing options...
Vivian-Trial Posted February 9, 2015 Report Share Posted February 9, 2015 I'd get a new rim with 31-32mm width. Try-All, Rockman, Clean etc. It would bring a tear to my eye butchering a set of pads. 1 Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 9, 2015 Report Share Posted February 9, 2015 I'd get a slim set of CNC backings like some Phatpads ones. Quote Link to comment Share on other sites More sharing options...
niconj Posted February 9, 2015 Author Report Share Posted February 9, 2015 (edited) I'd get a slim set of CNC backings like some Phatpads ones. I've got the TNN backings with ADM black pads. What I thought is to switch the rear pads as soon as they have worn down enough and put them on the front. Edit: Where can I find these Phatpads backings? Edited February 9, 2015 by niconj Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 9, 2015 Report Share Posted February 9, 2015 Wanted ad on here, not sure you can still buy them from anywhere??? They're 6mm thick though if that helps you measuring stuff up. Quote Link to comment Share on other sites More sharing options...
niconj Posted February 9, 2015 Author Report Share Posted February 9, 2015 Wanted ad on here, not sure you can still buy them from anywhere??? They're 6mm thick though if that helps you measuring stuff up. I'll measure my TNN backings.... I'm kinda undecided whether to get a new rim (and new spokes) or just use worn down pads from the rear... Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 9, 2015 Report Share Posted February 9, 2015 TNNs are 7mm IIRC. Quote Link to comment Share on other sites More sharing options...
niconj Posted February 9, 2015 Author Report Share Posted February 9, 2015 TNNs are 7mm IIRC. Not worth the hassle then. Kinda sucks. I tried to find a 32mm(isn) front rim with an ERD of the Trialtech rim and 32 holes to be able to use the front hub and spokes but it's impossible. Quote Link to comment Share on other sites More sharing options...
trials26 Posted February 10, 2015 Report Share Posted February 10, 2015 Hi, I'm pretty sure the front rim that comes on the Sky2 complete bike (Koxx sky rim) is 37mm wide (happy to be corrected). anyway, I had that rim, in the carbon forks for, well, years. I used Trialtech plastic backed pads in the front (I know pad choice comes down to preference) but I found this set-up ok... I also don't run my brakes really sharp. I appreciate the Trialtech rim is 39mm, and 1mm "each side" will make a huge difference when trying to chase mm's but still... Try some clamps similar to Tryall's too? might give that slight more adjustment? Secondly give Tryall crocco yellow pads a go on the front. I believe they are a little slimmer too? Cheers. Barry. Quote Link to comment Share on other sites More sharing options...
niconj Posted February 10, 2015 Author Report Share Posted February 10, 2015 Hi, I'm pretty sure the front rim that comes on the Sky2 complete bike (Koxx sky rim) is 37mm wide (happy to be corrected). anyway, I had that rim, in the carbon forks for, well, years. I used Trialtech plastic backed pads in the front (I know pad choice comes down to preference) but I found this set-up ok... I also don't run my brakes really sharp. I appreciate the Trialtech rim is 39mm, and 1mm "each side" will make a huge difference when trying to chase mm's but still... Try some clamps similar to Tryall's too? might give that slight more adjustment? Secondly give Tryall crocco yellow pads a go on the front. I believe they are a little slimmer too? Cheers. Barry. Thanks Barry but I think that the forks have been changed or sth. There's no way that a 37mm rim fits through my forks using standard pads. I'll get a 32mm rim I guess. Cannot trim down pads every time I get new ones. Quote Link to comment Share on other sites More sharing options...
craigjames Posted February 10, 2015 Report Share Posted February 10, 2015 I used a neon front rim in my TryAll Karbons, not sure of the ERD of them though. It was a squeeze at 35mm wide. Sell your existing wheel and then buy a new one? 1 Quote Link to comment Share on other sites More sharing options...
niconj Posted February 10, 2015 Author Report Share Posted February 10, 2015 (edited) I used a neon front rim in my TryAll Karbons, not sure of the ERD of them though. It was a squeeze at 35mm wide. Sell your existing wheel and then buy a new one? I just bought a different rim (Kabra 32mm) and new Spokes. I will rebuild the wheel with the existing rim and spokes as soon as I get a special offer on the Echo TR hub I build it with. Then I'll sell the wheel. For now I am happy with the 100gr. weight loss on the front even though I would've liked a wider and heavier rim as it's more stable I think. Edited February 10, 2015 by niconj Quote Link to comment Share on other sites More sharing options...
dave33 Posted February 14, 2015 Report Share Posted February 14, 2015 I don't think the forks have changed. I have an old pair I can measure the pitch of. You could always get some cnc backings skimmed down a couple of mm ? The trial tech pads work well as barry mentioned Quote Link to comment Share on other sites More sharing options...
