tomireland Posted January 25, 2015 Report Share Posted January 25, 2015 I bought a second hand Onza T-Bird at te tail-end of last year and it has got the old Magura HS11 hydraulic rim brake on the rear. It came with the standard Magura factory pads which were okay, but I've replaced them Rockman Greens. Problem is, they are REALLY close to the rim and rubbing against the sidewall of the tire. I cannot seem to shift the pistons/slave cyclinder (not sure about terminology there) back further to move the pad away from the rim. Any ideas or tips? Cheers. Tom Quote Link to comment Share on other sites More sharing options...
HippY Posted January 25, 2015 Report Share Posted January 25, 2015 On 1/25/2015 at 11:33 AM, tomireland said: I bought a second hand Onza T-Bird at te tail-end of last year and it has got the old Magura HS11 hydraulic rim brake on the rear. It came with the standard Magura factory pads which were okay, but I've replaced them Rockman Greens. Problem is, they are REALLY close to the rim and rubbing against the sidewall of the tire. I cannot seem to shift the pistons/slave cyclinder (not sure about terminology there) back further to move the pad away from the rim. Any ideas or tips? Cheers. Tom HS11 does not have a TPA ( a small screw that you can adjust the pads) but try this. There are 2 bolts on your mount, screw one of them out for half a turn-1 turn. After pull the brake slightish. the caliper will push itself away from the rim evenly, then just tighten the bolts, and voila Quote Link to comment Share on other sites More sharing options...
tomireland Posted January 25, 2015 Author Report Share Posted January 25, 2015 Thanks for the tips. I ended up doing something similar, but had to move the rear wheel forward a touch. Slackens the chain a wee bit, but now stops like nothing else. Cheers! Quote Link to comment Share on other sites More sharing options...
HippY Posted January 25, 2015 Report Share Posted January 25, 2015 On 1/25/2015 at 8:40 PM, tomireland said: Thanks for the tips. I ended up doing something similar, but had to move the rear wheel forward a touch. Slackens the chain a wee bit, but now stops like nothing else. Cheers! you could also move the mounts forward and rear a bit, so you can adjust the wheel to the best position for the chain have a play with them, there is a tarty video how to set up them properly that might help you! Quote Link to comment Share on other sites More sharing options...
niconj Posted January 26, 2015 Report Share Posted January 26, 2015 How come that the HS11 doesn't have a TPA. From what I know it does have one. It's just you have to use an allen key. Quote Link to comment Share on other sites More sharing options...
Aldred_85 Posted January 27, 2015 Report Share Posted January 27, 2015 Turbo Pad Adjuster implies lack of allen key to adjust. Its got APA or Allen pad adjuster. Lol! Quote Link to comment Share on other sites More sharing options...
HippY Posted January 27, 2015 Report Share Posted January 27, 2015 On 1/26/2015 at 9:58 PM, niconj said: How come that the HS11 doesn't have a TPA. From what I know it does have one. It's just you have to use an allen key. got rekt Totally forgot about that, sorry Quote Link to comment Share on other sites More sharing options...
