adding gears
lankyri
Evening all just wondering really as im slowly upgrading my mtb and is it just me or is everything these days 10 speed im currently running triple on the front and 8 on the rear with a std 135mm hub xan I add more gears on the rear or is ten speed for hubs that are 150mm hubs
Just put a 10 speed cassette, chain, mech and shifter on there and you're good to go - fits standard 135mm hub. Also worth investing in a narrow/wide single ring up front, saves a tonne of weight and makes the drivetrain virtually silent :)
I'm using 1x9 32t up narrow/wide front and 11-34 cassette, plenty low enough gears for any* of the hills up cannock chase :)
*Apart from perhaps the return paths back up to the top of stilecop downhill but who rides up them? :D
I'm 1x9 on 11-36 with a 36t up front
