freewheel fitting
HippY
Well, 3rd thread mainly concentrated on one problem..
I got the sprocket off thank god, but now I have a different problem.
I fitted the sprocket and tightened with hand lightly. that means the bashring is completely stable, does not move around, so it is tight enough for the test fit
There is 2 lines of thread visible on the freewheel. I know it will get tighter when I will pedal, but I do not believe that it has 2 thread (2 mmish) distance to travel
Is it safe to use it this way, or I should remove it and get a new bashring (= freewheel tool and bashring, so rather expensive)
Can't quite work out what you mean... Any chance of a pic?
It'll be fine
EDIT: I think he means when he's screwed the freewheel on there's still a couple of threads showing on the inside where it overhangs the crank arm near the BB.
yes, that
thank you guys!
All I need is a chain, because this Z610HX seen so much force and pressure from vices...
