Trialtech high-riser reduced ?
marcel-ahrens@live.de
Before you cut your bars to 66cm, maybe you should move your brake levers and grips to where they would be if you did cut your bars down to experience it first? At least that way if it feels too narrow you can move them back out again, whereas if you cut your bars down straight away you're stuck with them like that.
  • Like 2
