Suitable chainrings
onzatpro09
Hi guys,
A while ago I bought a set of Shimano SLX cranks, but I have never been down the whole hollowtech (or anything other than screw-on) crank system route before. They came with a 22 tooth chainring, but it has all of the shifting tabs and other gear-change related stuff like slanty teeth, so I'm not sure if I should use it...
My question is:
Can you recommend a good, strong, single-speed 22 tooth chainring for trials use, preferably in black?
Any suggestions are much appreciated,
Joe.
Edited by onzatpro09
Hi i use a xtr 22t on my saints(no problem) have been using slx 22t in the past no problem...Up front the Alu rings seems to hold up okay 6-8 months at least...chain is kmc 610hx, on the rear i use guesset wide sprocket (all other ive tried seems to dig in a lot..)...if you dont like the shimano rings blackspire make a "mono velocity" ring for single speed (CRC used to have them.)
