murga Posted December 16, 2014 Report Share Posted December 16, 2014 Is it possible to fit a Chris king bmx hub on a 24" frame guys? Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 16, 2014 Report Share Posted December 16, 2014 If it's a 116 rear end then I don't see why not Quote Link to comment Share on other sites More sharing options...
murga Posted December 16, 2014 Author Report Share Posted December 16, 2014 What frame would you recommend? Quote Link to comment Share on other sites More sharing options...
niconj Posted December 16, 2014 Report Share Posted December 16, 2014 What frame would you recommend? Depends on what type of trials you wanna ride. Quote Link to comment Share on other sites More sharing options...
murga Posted December 16, 2014 Author Report Share Posted December 16, 2014 Wanting to get into street now. Just built a 20" mod but think I've out grown mods now wanting something bigger but not stock Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted December 16, 2014 Report Share Posted December 16, 2014 Most street frames have a 135mn rear end so a Chris King Bmx hub won't work unless you have a custom frame like a Marino built for you and you specify a 116mm back end. Quote Link to comment Share on other sites More sharing options...
murga Posted December 16, 2014 Author Report Share Posted December 16, 2014 Is there no frames out there with 116mm rear end? It seems a shame to have the hub sat there going to waste... Quote Link to comment Share on other sites More sharing options...
dngr2self Posted December 16, 2014 Report Share Posted December 16, 2014 Could a King be modified to 135mm? Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted December 16, 2014 Report Share Posted December 16, 2014 I think one of the more "trialsy" 24" bikes has a 116mm back end. Not sure about the hub but changing the axle and freehub body might work. (If anybody knows for sure please correct me) Quote Link to comment Share on other sites More sharing options...
bing Posted December 17, 2014 Report Share Posted December 17, 2014 (edited) My echo 24 has a 116mm back end. All the disk versions though are 135mm. A Chris king BMX hub will fit, as will a profile mini cassette. A hope pro 2 BMX hub will fit as well but gearing is the issue with those, it's either a 9t driver or a 15t bolt on sprocket Edited December 17, 2014 by bing Quote Link to comment Share on other sites More sharing options...
murga Posted December 17, 2014 Author Report Share Posted December 17, 2014 Thanks for all your help guys appreciate it Quote Link to comment Share on other sites More sharing options...
