36 hole hub on 32 hole rim
FalseProphecy
If you "can't be arsed" to buy a hubshell then you certainly won't be arsed to do a decent job of it. If you can't track down a rim to fit (although there are still plenty about) then your best bet would be to buy another hub/wheel and sell yours to cover the cost. Second hand stuff is dirt cheap (Y)
it's no bother and I've done half a dozen or so. The wheel works perfectly well and lacing up usually works itself out , i.e. you'll put in a spoke hole where the spoke will very obviously not reach or tighten up, then put it in the one next to it that will.
Have a go. Just lace/tension it as if it was a normal 32h build - round of 8, flip the wheel over, another round of 8 and so on and so forth.
Edit: I've just thought of a top tip. Buy spoke nipples - If u have standard 12mm nipples that usually come with spokes, replace them with 14 or 16s, it'll make it so much easier as you'll never have the situation where the spoke isn't long enough to thread in to the nipple.
It is SO f**king annoying when this happens!
Edited by CC12345678910
