2004 beta 270 HELP, not starting
Anthc24
Hi, new here, got myself a trails bike last year to ride over the winter as I race mx, basically when I out it away after the winter it wasn't running, iv just got it back out to fix ready for the winter and it started after a few kicks with no petrol in and I think the petrol was even turned off! It cut out and couldn't get it going again even when I put petrol in. When I put petrol in it came p***ing out of one of the pipes going down towards the back shock, guessing this is an overflow? I stripped the carb down and there was green stuff in the bottom of the float bowl and on the jet, green hard stuff. Cleaned everything up and still won't fire.
Any help is much appreciated
Regards
This isn't a moto trials forum but anyhow, there's a few guys on here who may be able to help.
Is it still leaking when the fuel tap is turned on? Could be flooding because the floats are filled with petrol or the float valve's stuck. Green stuff sounds pretty tragic too hah. Would check over and make sure all the jets are as clean as a whistle
But of advice, if you are planning on laying the bike up for a while, drain the carb of petrol first, make sure the float bowl is empty. Your issue is More than likely dried gummed up petrol/oil mix bunging up the needle valve, which will hold it open and cause the float bowl to overfill, hence it coming out of the overflow pipe. The way I do it is to take the carb off, completely strip it down and clean it in an ultrasonic bath, something like a jewellery cleaner. Gets all the shite out of the little galleries.
