WTF with Inspireds geo info?
Clerictgm mk2
We use a guide (Vice steerer clamp holder) from the center of the Fork steerer tube and measure from there to the center of the front hub, and you've got the fork offset. We have also Measured from the center of the crank fixing bolt to the center of the From axle, then you can turn the fork around and measure again then divide by 2, Both ways by no means scientific but usually within .5mm
