tdubz Posted September 21, 2014 Report Share Posted September 21, 2014 Which size kmc 610 do i need to go through a rohloff tensioner? Is it the 1/8 or the 3/32? Thanks Tom Quote Link to comment Share on other sites More sharing options...
Blake Posted September 21, 2014 Report Share Posted September 21, 2014 3/32Actually the 610 is thin regardless so it doesn't matter Quote Link to comment Share on other sites More sharing options...
tdubz Posted September 21, 2014 Author Report Share Posted September 21, 2014 Thanks More riders on tarty site seem to run the 3/32... Any reason for that? Quote Link to comment Share on other sites More sharing options...
Blake Posted September 21, 2014 Report Share Posted September 21, 2014 No idea mate think they just run it because they all know it works Quote Link to comment Share on other sites More sharing options...
Disc.Jokie. Posted September 21, 2014 Report Share Posted September 21, 2014 sorry for changing the topic here but, what is the difference? Quote Link to comment Share on other sites More sharing options...
Blake Posted September 21, 2014 Report Share Posted September 21, 2014 sorry for changing the topic here but, what is the difference? Widths Quote Link to comment Share on other sites More sharing options...
Vivian-Trial Posted September 21, 2014 Report Share Posted September 21, 2014 1/8" chain is used on most single-speed bicycles, and bicycles with internal gearing. 3/32" chain is used on derailer equipped bicycles that have more than 3 speeds. Quote Link to comment Share on other sites More sharing options...
Jake. Posted September 21, 2014 Report Share Posted September 21, 2014 1/8" chain is used on most single-speed bicycles, and bicycles with internal gearing. 3/32" chain is used on derailer equipped bicycles that have more than 3 speeds. Exactly, so why does everyone seem to think a thinner chain is stronger these days? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted September 22, 2014 Report Share Posted September 22, 2014 Exactly, so why does everyone seem to think a thinner chain is stronger these days? They're not stronger they're just no weaker for a lighter weight. If you run a 1/8" chain for the sake of it you're just carting round extra metal for no reason. Quote Link to comment Share on other sites More sharing options...
ZArgrave Posted September 22, 2014 Report Share Posted September 22, 2014 Exactly, so why does everyone seem to think a thinner chain is stronger these days? Or in your case a chain that could move small countys jake 1 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted September 22, 2014 Report Share Posted September 22, 2014 Exactly, so why does everyone seem to think a thinner chain is stronger these days? Do they? Only difference is roller and pin width, plates are identical. But anyway, Z610HX is all good. Quote Link to comment Share on other sites More sharing options...
casualjoe Posted September 22, 2014 Report Share Posted September 22, 2014 A 1/8" can move side to side more on the sprocket, putting uneven loading on the pins and therefore more wear on the rivets. This is 100% fact maybe. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted September 22, 2014 Report Share Posted September 22, 2014 610 is 3/32" 510 is 1/8" Reason most riders is use the 610 is because that is the same size as the singlespeed freewheels, chainrings and sprockets we all use. There's nothing to be gained in using the wider 1/8" chain Quote Link to comment Share on other sites More sharing options...
N.Wood Posted September 22, 2014 Report Share Posted September 22, 2014 A 1/8" can move side to side more on the sprocket, putting uneven loading on the pins and therefore more wear on the rivets. This is 100% fact maybe. To add a bit more 100% engineering fact, the longer pins also allow more leverage and therefore flex leading to a 0.2% increase in run-up distances. Quote Link to comment Share on other sites More sharing options...
Martin Direske Posted September 22, 2014 Report Share Posted September 22, 2014 (edited) Just for those who are interested: I used to run a KMC Koolchain 810 (the slightly smaller version of the common 710) in combination with the Rohloff tensioner on the Skye. It worked out with no issues. Might be helpful for those who won't rely on other chains than the Koolchain, just like me Edited September 22, 2014 by Martin Direske Quote Link to comment Share on other sites More sharing options...
Jake. Posted September 23, 2014 Report Share Posted September 23, 2014 Do they? Only difference is roller and pin width, plates are identical. But anyway, Z610HX is all good. Maybe between the z610 and 510 yes... But not compared to other chains. I'll be very very surprised if my chains plates were anything smaller than triple the width of the kmc chains. Quote Link to comment Share on other sites More sharing options...
