Martin Direske Posted September 22, 2014 Report Share Posted September 22, 2014 It is is what? Stop building up so much tension. WTF?!!! It is IS (mount). It is is what though? :bow: 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 22, 2014 Report Share Posted September 22, 2014 youve been trolled hard,nico Quote Link to comment Share on other sites More sharing options...
niconj Posted September 22, 2014 Author Report Share Posted September 22, 2014 youve been trolled hard,nico Damn and I just saw "The desolation of Smaug"... Quote Link to comment Share on other sites More sharing options...
Perez Posted September 23, 2014 Report Share Posted September 23, 2014 Just grind the rotor, i,ve done it a few times, no problems. Quote Link to comment Share on other sites More sharing options...
niconj Posted September 23, 2014 Author Report Share Posted September 23, 2014 Just grind the rotor, i,ve done it a few times, no problems. For the record. I bough a 175mm rotor from Tarty which should arrive soon so the problem is solved. Thank you! Quote Link to comment Share on other sites More sharing options...
Perez Posted September 23, 2014 Report Share Posted September 23, 2014 Oh ok, didn't saw that Quote Link to comment Share on other sites More sharing options...
niconj Posted September 23, 2014 Author Report Share Posted September 23, 2014 End of story. Got the 175mm rotor today and put it on. Fits perfectly and to my great surprise, there's no rubbing whatsoever when spinning the wheel. I didn't even have to face the IS mount. Now I just hope that Hope holds longer than my Zee, which was swapped for a new one under warranty. It's also braking pretty well considering that neither Jitsie pads nor Rotor are bedded in yet. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 23, 2014 Report Share Posted September 23, 2014 Now I just hope that Hope holds longer than my Zee It will. That brake will work great, chuck some cold, clean water on the rotor and drag it on and off a bit while riding round, will bed in faster. 1 Quote Link to comment Share on other sites More sharing options...
niconj Posted September 24, 2014 Author Report Share Posted September 24, 2014 I just got a mail from Echo: "This problem can be easily solved by using a half link chain or extra link of chain. There is nothing wrong with your parts but just the chain, please give it go and see how it fit." You can imagine my answer to them. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted September 24, 2014 Report Share Posted September 24, 2014 Is is it abusive? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 24, 2014 Report Share Posted September 24, 2014 is is what is is 1 Quote Link to comment Share on other sites More sharing options...
niconj Posted October 15, 2014 Author Report Share Posted October 15, 2014 (edited) Echo Quality Team wrote: We have done some searching on the frame number that you have provided earlier, we did not discover the problems on this batch of frames. If you check on our website and you will see that 24” bikes comes with 180mm discs, that means we have sold lots of frames/bikes together with 180mm discs brake without any problems. We did make one batch of frames that has lower mount but that’s 26” frames not 24” frames. Have you tried using our 180mm disc brake on the frame? I understand that our disc/brake is not perfect as others but this might be the solution for the problem. Funny that not only Tarty but my German dealer as well have come around the same problem with the f**king 24'' frame. Edited October 15, 2014 by niconj Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 15, 2014 Report Share Posted October 15, 2014 welcome to china. Quote Link to comment Share on other sites More sharing options...
