Scott Gibbs Posted September 11, 2014 Report Share Posted September 11, 2014 I've got a set of Tensile Ultimate cranks with the 22t bashring like this I want to take it off to run a 18t sprocket. The problem is it's stuck on like a b*****d! What is the best way of removing it without destroying it or the crank threads? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 11, 2014 Report Share Posted September 11, 2014 Put the chainring back on, then same way you'd remove a screw on sprocket. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted September 12, 2014 Author Report Share Posted September 12, 2014 Got it off at work today so it's all good Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted September 12, 2014 Author Report Share Posted September 12, 2014 (edited) Put the chainring back on, then same way you'd remove a screw on sprocket. Got a question Adam, the cranks have 12mm of thread is this enough for a bashring and freewheel? Edited September 12, 2014 by Scott Gibbs Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 12, 2014 Report Share Posted September 12, 2014 Says on Tarty Please note that the minimum required thread contact between crank arm and sprocket/freewheel is 7mm So assuming you use a bashring no thicker than 5mm you should be good Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted September 12, 2014 Author Report Share Posted September 12, 2014 Cool cheers dude Quote Link to comment Share on other sites More sharing options...
