jack dickinson Posted September 4, 2014 Report Share Posted September 4, 2014 ive a magura hs33 lever with a plastic tpa. help on how to get it free?, the person before me obviously doesn't know what greese is. dont care if have to break the tpa system just need it free. thanks in advance. jack Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 4, 2014 Report Share Posted September 4, 2014 It's not grease that's the issue, the fact it's made out of plastic is the issue - using the brakes for trials with the TPA wound out basically forces it to cross thread and/or eat shit. You should be able to rag it around just using some mole grips or something similar. It is just plastic, so you just need to mash it around the threads enough to get the TPA pin to work its way out. Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted September 4, 2014 Author Report Share Posted September 4, 2014 It's not grease that's the issue, the fact it's made out of plastic is the issue - using the brakes for trials with the TPA wound out basically forces it to cross thread and/or eat shit. You should be able to rag it around just using some mole grips or something similar. It is just plastic, so you just need to mash it around the threads enough to get the TPA pin to work its way out. thanks for your help, its the reason i dont care if it break on removal because i have a spare metal one to insert. p.s. thanks for your help Quote Link to comment Share on other sites More sharing options...
