williams Posted August 31, 2014 Report Share Posted August 31, 2014 (edited) Hello going to build up a onza mod next week and are about to order a new disc hub for it on the rear, when I suddenly noticed that it says on every hub that it wont be compatible with onza frames and disc brakes? The only ones that doesn't have that text is the trialtech sport lite disc hub 116 mm and Neon sealed rear disc hub. So does any of these fit my onza or am I f**ked? My mate had problems with his onza rubbing the frame, but he just put a spacer on the disc side and it sorted it... Edited August 31, 2014 by williams Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 I will be using chain tugs if that makes any difference Quote Link to comment Share on other sites More sharing options...
MartMini Posted August 31, 2014 Report Share Posted August 31, 2014 Monty hubs fit aswell and have correct disk alignment Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 (edited) Monty hubs fit aswell and have correct disk alignment Yes I just saw that, but their screw on bit for the sprocket looks abit shitty.. I mean, look at this, is this even threads? What makes the hub not fit on a onza frame? Is it because the frames spacing is 110? and most hubs are 116? Because if so the trialtech has 3mm spacers on both sides that can be removed, and I could just put the chain tugs on the outside. This should work??? Edited August 31, 2014 by williams Quote Link to comment Share on other sites More sharing options...
MartMini Posted August 31, 2014 Report Share Posted August 31, 2014 Yes I just saw that, but their screw on bit for the sprocket looks abit shitty.. I mean, look at this, is this even threads? SSSS.PNG What makes the hub not fit on a onza frame? Is it because the frames spacing is 110? and most hubs are 116? Because if so the trialtech has 3mm spacers on both sides that can be removed, and I could just put the chain tugs on the outside. This should work??? its more to do with the disk alignment that's the issue. i ran a monty hub fine, but i do know what you mean about the threads, they do look dodgy as. Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 its more to do with the disk alignment that's the issue. i ran a monty hub fine, but i do know what you mean about the threads, they do look dodgy as. Ah I see.. How long did you run your hub? Did you have the same dodgy threads? Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 Going to buy that monty hub then, thanks for the help Quote Link to comment Share on other sites More sharing options...
bing Posted August 31, 2014 Report Share Posted August 31, 2014 Get a viz disk hub, they work spot on. I had one on my 09 blade Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 31, 2014 Report Share Posted August 31, 2014 V!z or Monty is what you need, preferably v!z. Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 Shame tarty don't stock the v!z disc hub Bought the monty, had no choice Quote Link to comment Share on other sites More sharing options...
bing Posted August 31, 2014 Report Share Posted August 31, 2014 Trials addict do viz hubs. Bit late now I suppose Quote Link to comment Share on other sites More sharing options...
williams Posted August 31, 2014 Author Report Share Posted August 31, 2014 Trials addict do viz hubs. Bit late now I suppose Thanks, but yes it's to late now, plus I do want to order everything on one website, and get it all on the same day Quote Link to comment Share on other sites More sharing options...
Blake Posted August 31, 2014 Report Share Posted August 31, 2014 I love how onza hubs don't work with their frames Quote Link to comment Share on other sites More sharing options...
Herbertlemon102 Posted September 1, 2014 Report Share Posted September 1, 2014 I love how onza hubs don't work with their frames this. I honestly do t see the point of making a frame that won't fit their own parts- surely you'd make it so it only fitted onza hubs, so you have to come back to onza to replace the hub, therefore making them more money etc Quote Link to comment Share on other sites More sharing options...
