Perez Posted August 27, 2014 Report Share Posted August 27, 2014 (edited) As the title says, does anyone fitted a different brand on a Echo disc brake? Shimano or Magura? Thanks in advance. Edited August 27, 2014 by Perez Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 27, 2014 Report Share Posted August 27, 2014 You mean the hose? Any hose will work with the correct fittings though if you want to retain the originals then Magura should be fine. Quote Link to comment Share on other sites More sharing options...
Perez Posted August 27, 2014 Author Report Share Posted August 27, 2014 You mean the hose? Any hose will work with the correct fittings though if you want to retain the originals then Magura should be fine. Yes, i was meaning the hose, sometimes i crash my english ahaha. Do you know if Shimano will work? Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 28, 2014 Report Share Posted August 28, 2014 Not sure what it'd be like with the fittings, may be worth sending Tartybikes an email for a definite answer! Quote Link to comment Share on other sites More sharing options...
crilin202 Posted August 28, 2014 Report Share Posted August 28, 2014 Yes Perez, ive used them both shimano and magura as I tend to break the back one fairly often... you would need a special clamp to hold the hose on a vice and hen press the metal bit on. Any bike shop should have them and it only takes 1 minute to do it Quote Link to comment Share on other sites More sharing options...
Perez Posted August 28, 2014 Author Report Share Posted August 28, 2014 Yes Perez, ive used them both shimano and magura as I tend to break the back one fairly often... you would need a special clamp to hold the hose on a vice and hen press the metal bit on. Any bike shop should have them and it only takes 1 minute to do it Thanks buddy, i have that clamp, its just like doing the same when you fit new hoses on Shimano disc brakes. Thanks for the feedback guys! Quote Link to comment Share on other sites More sharing options...
