Clerictgm mk2 Posted August 23, 2014 Report Share Posted August 23, 2014 1) Now biggest drop I've done is 1.7m. Is there much difference between 1.7 and 2.45m? I can't find a wall between that two, so it seems that I forced to try 2.45 right away after 1.7m. 2) What height is optimal to start learning 360 exits? I've tried 40cm but it's kinda low. 3) I can do 180 pretty well but stuck at learning 360's any advice? Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted August 23, 2014 Report Share Posted August 23, 2014 start low, build it up. even if it looks "too low" perfect it on them the best u can Quote Link to comment Share on other sites More sharing options...
eskimo Posted August 23, 2014 Report Share Posted August 23, 2014 Lower the better. It'll teach you to spin. If you're having to land with your back brake on you're probably not spinning enough. If you're not rolling out with much speed, then again the spin probably isn't correct. The above applies primarily for lower drops. Higher drops focus on smoother landings in a different way 1 Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted August 24, 2014 Report Share Posted August 24, 2014 http://www.bmx-forum.com/f/ Here you go mate. Haha, when changing from a 180 to a 360 drop off I think it's easier when it's higher. Maybe try something around the 1m height. That's all I feel comfortable doing it at, but what do I know, I'm a tgs faggot Quote Link to comment Share on other sites More sharing options...
