isitafox Posted August 23, 2014 Report Share Posted August 23, 2014 Fitted some new pistons the other day then went to bleed my brake last night and even when I was bleeding it the lever wasn't returning fully, any ideas why? Seeing how i've fitted new pistons and seals is it worth fitting a new lever piston as well in case the spring has had it or is there some other cause I'm missing? Quote Link to comment Share on other sites More sharing options...
bing Posted August 23, 2014 Report Share Posted August 23, 2014 Yes. For the small price they are, its worth doing. Think I did my old mono trial lever piston and all seals for about a Tenner off chain reaction Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 23, 2014 Author Report Share Posted August 23, 2014 I think before I do anything else I'm gonna take the new pistons out and make sure the seals are well greased with some silicone lube,refit them then rebleed it and see how that goes Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 23, 2014 Report Share Posted August 23, 2014 Is it possiblev the previous owner has f**ked the brake in some way? Such as bleeding it with mineral oil? I've never seen a sticky Hope lever other than for that reason, even ones that are closing in on 20 years old! Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 23, 2014 Author Report Share Posted August 23, 2014 Could be a possibility, is it fixable or past it?? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 23, 2014 Report Share Posted August 23, 2014 Perfectly fixable, would just need new seals. Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 23, 2014 Author Report Share Posted August 23, 2014 Will pop the caliper pistons out again, regrease them and try another bleed and if that fails I'll probably stick it in the post to you for a service then! Quote Link to comment Share on other sites More sharing options...
bing Posted August 23, 2014 Report Share Posted August 23, 2014 Pop them out Dave, and the master cylinder piston and seals, and blather the lot with solvent brake cleaner, to get any traces of shite out Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 23, 2014 Report Share Posted August 23, 2014 Nah don't use grease, just a bit of dot fluid is all you need. If you think the problem is in the lever, sort that first or you're just wasting your time Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 24, 2014 Author Report Share Posted August 24, 2014 I've found a solution, it's a brown envelope with the Tartybikes address written on it. With the addition of some stamps I think the problem will be taken care of! 2 Quote Link to comment Share on other sites More sharing options...
