Where to start at the wrong side of 40
Matt1973
Hi. Ok so I have wanted to get riding trials for ages, and have been bouncing around on my hardtail bike for years. I'm 41, about 12st and 6ft. Been riding MTB for well over 20yrs - never gone full sus and love the feel of a good quality rigid bike. I'm looking to buy a 2nd hand trials bike, and would benefit from some experienced advice and info. Having played around on my hardtail with the seat removed, I'm confident that 'no seat' is the way I want to go, but thats where it ends really. I'm not sure whether to go 20, 24 or 26. Obviously used to riding 26, but wonder if I'd benefit from a smaller wheel especially to start with. My budget will be restrictive for sure at around £300/350, but seen plenty of bike on eBay for around that price.
Please help any way you see fit. CHEERS!
Hey welcome to trials man :) 26" would be the best option to go for based on your riding background but, you have to bear in mind the radical geometries of pure trials frames if you're dead set on one. The cockpit will feel more compact but higher than what you're used to so the higher BB frames (e.g. +70mm) will feel really odd to ride coming off a MTB background - as they're better suited doing moves on one wheel than two. But for any rolling moves like manuals and bunnies, it will feel shit.
Have you considered the Inspired Hex? The geometry is much better balanced than pure trials frames, allowing you to do a lot more than just rear wheel and static moves. If you're leaning towards a streetier style with bunnyhops and manuals being part of your moveset then definitely look into the Hex. Much stronger than today's pure trials frames, and can do pure trials moves very well. Probably the best bike to start out on now if you want to explore what style of trials you want to get good at since its geometry allows it to ride well as both a big BMX and trials bike.
Take a look through the For Sale section of the forum, you'll find something good within your budget. Starting out on an older frame with lower BB can be better for the long term as it forces you to learn proper bike handling and control, and then you'd feel the benefits way more when you eventually move onto higher BB frames. If you find a bike you like, post it up and I'm sure other members of the forum will give you their pointers and advice on what's a good deal and what's good to learn on.
(Y)
Hey bud,
I just so happen to have two 26" full builds (well almost full builds! :blink:) with a slightly older style of geometry, but still modern enough to feel "trialsy". Both bikes are more durable than the newer style bikes and would be an excellent 1st bike. There are a number of pictures and spec in my topic "Neil's Big Sale" in the F/S section.
I'm more than happy to have a chat if you're interested…or just if you need a chat from one of the elder members of the forum about "stuff".
Neil :w00t:
  • 2 weeks later...
Finally bought my bike. However after having my car fixed, my budget was somewhat reduced!!
So Ive bought a pretty tidy looking MAD Phase 1.
From what I've read it can make a pretty good starter bike, and with a few upgrades could potentially last me a while.
Anyone had one of these? How do I convert to single speed?
Thanks, Matt
I'd use this (the tab in knuckle bit may need removing) and add this as its the cheapest one stop set up I can think of.
Assuming you will be using the standard cranks and 22t sprocket, (Pics of your exact bike would be helpful) buy either the 18t (i'd consider this the 'norm' when converting a phase) or a 17t. Either way buy the tensioner in long arm version.
If you value your knee cartilage/gonads/teeth, buy a good chain too. My personal rule is that if a chain don't say KMC on it, then it isn't going on my bike. As such I'd stress buying either this/this (In 1/8 form it is the same thing) This is what i've been running for waaay longer than I should of. The 510HX is the better of the 3 because 710's can stretch so much.
Just a heads up that the tensioner may require the fitment of two washers between the jockey wheels and the chain cage. Simply remove the cage nearmost in this picture, put in a 2.5mm-ish washer on both the shaft and bolt then whack it back together.
Hope all that lot helps and sorry if it were a bit 'painting by numbers' for you - I don't intend to patronise.
Ciaran
Edited by CC12345678910
