Removing a snapped pedal axle
onzatpro09
I know how to remove the axle if it wasn't damaged (which seems to be what you're describing?) but can't because when I turn the socket, the axle spins with it and I can't get a purchase on the axle because it has snapped half way into the body :/
How deep is the rest of the axle in the pedal body? I'd suggest going to bearing/industrial supplies/ good tool shop and getting a set of 'easy out'. You drill a hole in the middle of the snapped axle, and then the easy out is very course revers thread that you screw into it, therefore loosening the remaining axle? Try that if no one else can give you a better solution?
