Sort of Split Tyres...
I was out riding today and I was making my way up a steep slope by hopping up but my rear tyres sidewall caught a sharp rock and has cut the outer layer of the tyre but not pierced it.
1. Does it need replacing?
2. Should I just use it until destruction?
I had problem with the wire bead on that tyre, kept poking out and popping the tube.
That's strange. I haven't had any punctures due to that, just poor riding skills and my tendency to go too quickly and not give myself enough time resulting in me smashing into things :P
Remove the tyre and see if the hole is right through, If it is, get a large puncture repair patch and repair the tyre from the inside as you would a tube.
Or, cut up an old inner tube to a piece around 6cm long - 3cm wide to cover the hole and use some proper duct tape to stick it to the inside.
  • Like 1
