Onza Genesis 26 2013 freewheel/bash issue
Trialsrob2014
just a quick question to you all:-) I'm having issues with my new bike and wondered if you could help identify the issue... Basically my freewheel is moving up/down/in/out causing tight spots and lose spots on the chain... Also when putting pressure on the peddles the cranks will move but not the freewheel... Have you got any ideas??? Much appreciated cheers Rob
Video Attached
Sounds like the freewheel is knackered and possibly the axle on the bb is bent. If its the standard ffw then you can service it while its still on the cranks. That should be the first port of call. It might be that the lock ring has come loose and the internals could just need resembling.
  • Like 1
