Help Hopping on the Rear Wheel
Hello peoples,
I have been trying to learn rear wheel hops for a few days now but I can only manage 3 on the spot. When doing them, I use an endo to help me lift the front wheel for the move but I can only do three hops before the front wheel lands back on the ground. If I try and lean further back and lift the front wheel more explosively, I simply lose my balance or fall off the back of the bike.
Any tips or is it just practise, practise, and practise some more...
I might make a vid soon.
Cheers Tom
Hello peoples,
Cheers Tom
Hello peoples,
I just practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practisejust practise, practise, and practise
Cheers Tom
As Accurate I could get
Edited by HippY
  • Like 1
I'd say don't try to lean back more to get over the rear tyre but try to push the rear wheel foreward with a pedal kick to get it underneath you.
You can then start hopping foreward for the start... at least that's what I did in he beginning.
and yeah.. practise, practise, practise :)
Edited by Max F
Its the inertia coming from the endo that holds you in the upright position long enough so you can hop. Once that force has gone, if your not moving forward or backward you'll need incredible balance to keep the front wheel in the air. Its easier to follow the original force and hop backward, pedal kicking to keep you upright takes a lot of practice, how hard to push, body position, brake timing ect all need to be in unison.
Edited by *gentlydoesit
  • Like 2
Practice and practice and then there's also practice.
Then when you are done with it then you should practice more.
And then comes the stage of the practice in which you stop for a few minutes every time you practice.
After that you look at the sky and practice some more; then you think about your life and practice again.
Once you are done with a few months of that (possibly like half a year if you were as bad as me) start pedal-kicking, just drop your front wheel a little bit and kick. You DON'T need flawless perfect balance to do pedal-kicks, and as a matter of fact pedal-kicks was what helped me stay on the rear comfortably until I get tired.
YES you will fall on your ass.
YES you will hurt yourself.
YES people will think you are a dumbass.
YES it's frustrating when everyone else is sidehoping buildings next to you and you can barely hop on the rear wheel.
YES there will be blood.
YES you will consider quitting.
If you go through ALL that, then congratulations, that's the easiest technique in trials, have fun and enjoy your bike.
  • Like 7
Isn't it hopping backwards what beginners usually do? Forwards would include pedal kicks.
Hmm, sounds like I learned it a little differently.
I never used endos to get on the rear, I always used pedal kicks and picked this technique up quite quickly.
But it's like driving cars.. after some months you look back onto how you did it months ago and it looks retarted to yourself :D
Endo or pedal kicking. I was always hopping backwards. You're right about the looking back part. Whenever I look at my not so old videos in my blog I laugh at myself and back then I felt like a king when I managed something new. (Not that I'm very good now)
  • Like 1
Thanks guys, I'll post a vid as soon as I can do it...
Honeslty the thing that I found is that the rear hub must be in front of you, and the rest of the stuff comes from practice
We can tell you to keep your arms loose, pull up the front wheel high and stuff, but you can read everything(and more) at trashzen.com, and honestly, you must feel it to know what to do
What I found easiest way as I've just learnt them, was to just stand on bike and pull front up for as long as I could just to help me find my upright balance, once I could hold it for a while I then started to hop. Gave up the other way as I was hopping all over the place into things and landing on my ass a lot. Thats what worked for me just getting the balance before the hop, doesn't hurt as much when you come off as well, lol. Also found pulling front up slowly helped better than trying to pull up hard and going to far backwards...
Just weight to start with then when felt a bit more of position I needed to be in I then started pedal to get up. I tried all the rocking before but as soon as decided to pedal kick up it felt like I was starting again so did it the way I said and I got it fairly easy the second night of trying
