Zog Posted June 17, 2014 Report Share Posted June 17, 2014 Hi this is my Onza Ska! More pics soon rest didnt come out in dark! Brand New! Specs: - 20" wheel trials bike from Onza with a 19" rear wheel- High grade 7005-T6 aluminium frame with head tube reinforcing gussets.- Tough Onza cromoly forks.- Both frame and fork are fitted with 4-Bolt mounts and V-Brake adaptors, making it easy to upgrade to hydraulic rim brakes in future if you wish.- Powerful Onza DD 'V' brake at the front and rear are fitted with upgraded sticky V-Brake Pads, offering great stopping power!- Drilled light weight single wall rim at the front reduces weight while the drilled 19" rear rim is double walled for extra strength and durability.- Fitted with Onza's new Sticky Fingers 2 tyres, 20 x 2.0" front and 19 x 2.5" rear.- Onza crankset fitted with a 30-engagement front freewheel and Comp-style bashring, with a 12t fixed sprocket on the rear wheel giving the ideal gear ratio for 20" bikes.- Bash/ski-plate fitted as standard.- Onza cromo riser 31.8mm trials handlebar.- Onza alloy 31.8mm stem to reduce weight.- New Onza caged pedals.- Seatless design saves weight and increases stand over clearance.- Satin blue finish with orange and yellow accents.- Weight: 10.80kg Quote Link to comment Share on other sites More sharing options...
onzatpro09 Posted June 17, 2014 Report Share Posted June 17, 2014 Nice bike, but I would advise getting a better freewheel (even if it was a tensile 60 Click) and some better brake pads, or even better, a magura rear brake and decent pads. It will help your progression So much! There's nothing Worse than freewheel Skips and brake slips when you're learning. It really damages your confidence. Hope this Is helpful! Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted June 17, 2014 Report Share Posted June 17, 2014 i run a tensile 60 click trust it more than echo sl ones Quote Link to comment Share on other sites More sharing options...
dngr2self Posted June 17, 2014 Report Share Posted June 17, 2014 It's a good bike. The brakes should be fine and from my experience the tensile 60 freewheel is really reliable. Quote Link to comment Share on other sites More sharing options...
