AlexClare94 Posted June 16, 2014 Report Share Posted June 16, 2014 Just on tarty and wanting to get the Hope Trial Zone Team Edition and it says only compatible with 180mm rotar and IS Mount forks, does IS mean industry standard? Or is it some special type of disc mount? Cheers Alex Quote Link to comment Share on other sites More sharing options...
Kevinfor Posted June 16, 2014 Report Share Posted June 16, 2014 IS and post mounts. And I think you can change rotor size if you get an adaptor, but wait till someone who know more than me answer. Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 16, 2014 Report Share Posted June 16, 2014 Yep, International Standard. Most trials forks are apart from the Trialtech Sport forks (which have a +20mm mount). Quote Link to comment Share on other sites More sharing options...
AlexClare94 Posted June 16, 2014 Author Report Share Posted June 16, 2014 Yep, International Standard. Most trials forks are apart from the Trialtech Sport forks (which have a +20mm mount). Sweet cheers man so I won't need an adapter for it to fit? The one that comes with the brake will fit fine? Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 16, 2014 Report Share Posted June 16, 2014 That depends on the forks you have. That type of brake doesn't have an adaptor, it just bolts on directly to the fork. Quote Link to comment Share on other sites More sharing options...
AlexClare94 Posted June 16, 2014 Author Report Share Posted June 16, 2014 That depends on the forks you have. That type of brake doesn't have an adaptor, it just bolts on directly to the fork. Echo SL 2014 Disc onlyOn tarty it says 180mm IS Mount + No Adapter....200mm IS Mount + 20mm adapter or + 20mm mount frame Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 16, 2014 Report Share Posted June 16, 2014 Bueno Quote Link to comment Share on other sites More sharing options...
AlexClare94 Posted June 16, 2014 Author Report Share Posted June 16, 2014 Bueno Woo!! Yeah been on tarty and started to build two bikes with the bike builder thing... I made a topic and created a GU26" but modded a few bits and bobs (9.0-9.4kg) .. And now I made an Echo Pure 26" some slight better parts and it only weighs 8.7-9.0 kg but the GU looks so much nicer Here's the spec off the Echo pure Frame Echo Pure SL: Grey, with Silver Titanium BB Forks Echo SL 2014 26" Front Hub Echo TR Non Disc Rear Hub Echo TR Rear Front Rim Echo SL Front 26" Rear Rim Crewkerz Freed 26" Rear Spokes Sapim Race 26", Black: With Brass Nipples Front Rim Tape Trialtech Rim Tape: White, Front, 26" Rear Rim Tape Trialtech Rim Tape: White, Rear, 26" Front Inner Tube Continental Supersonic 26" Rear Inner Tube Continental Supersonic 26" Front Tyre Kenda Small Block 8 26": 26" x 2.10" Wire Bead Rear Tyre Try-All Stiky Rear 26" Front Brake Hope Trial Zone Team Edition (No Rotor): Front, Right Hand, #5 Caliper Front Brake Pads Deciding on Jitsie Pads???? Front Brake Rotor (Optional) Hope Mono Trial: 180mm Rear Brake Magura HS33 2014 4-Finger, no brake clamps, with shroud nut and olive Rear Brake Clamps (Optional) Jitsie Brake Clamps: Black Rear Brake Pads (Optional) TNN Engineering LGM Green Pads Cranks Trialtech SL Forged ISIS: 170mm Freewheel (Optional) Jitsie 108.9 Rear Sprocket Jitsie Alloy Screw-On: 15t Chain KMC Z610 HX, 3/32" Pedals Trialtech Race Platform Bashring Jitsie 7075 Bashring: Black Headset Echo SL Headset: Black Stem Trialtech SL Grips Trialtech Foam: Thin Handlebars Try-All Carbon Riser (Silver Logo)Just realised I need a Disc hub up front Fs Quote Link to comment Share on other sites More sharing options...
