trialsquirt Posted June 11, 2014 Report Share Posted June 11, 2014 Hi, I've recently water bled my 04 magura hs33 and I was wondering if I should oil the brake? Cheers Quote Link to comment Share on other sites More sharing options...
Blake Posted June 11, 2014 Report Share Posted June 11, 2014 this forum is basically a water bleeding forum Quote Link to comment Share on other sites More sharing options...
trialsquirt Posted June 11, 2014 Author Report Share Posted June 11, 2014 I'm still not sure which parts to put oil on Quote Link to comment Share on other sites More sharing options...
Blake Posted June 11, 2014 Report Share Posted June 11, 2014 If you're not sure don't bother Quote Link to comment Share on other sites More sharing options...
dann2707 Posted June 11, 2014 Report Share Posted June 11, 2014 If you're not sure don't bother Mate that's such a shit attitude I had no idea when it came to cars when I was 17 but only trying, asking advice from people and learning from it made me do a degree in it a few years later. 1 Quote Link to comment Share on other sites More sharing options...
bing Posted June 11, 2014 Report Share Posted June 11, 2014 (edited) Hi, I've recently water bled my 04 magura hs33 and I was wondering if I should oil the brake? Cheers No you shouldn't. Oil and water don't mix. If you need to lube the lever piston, you need a water based lubricant like the stuff they use to lubricate spray guns. For the slaves, I squeezed the lever in to push them out, then gave them a light spray with silicone spray. Always worked for me Edited June 11, 2014 by bing Quote Link to comment Share on other sites More sharing options...
