Culshaw95 Posted June 2, 2014 Report Share Posted June 2, 2014 Hi I was just wondering what the best glue to use for putting in refills? I used Loctite but my pads are slowly coming out the backings so I have to stop each time the sound of my rear brake goes Quote Link to comment Share on other sites More sharing options...
thinkdougie Posted June 2, 2014 Report Share Posted June 2, 2014 Ive always used super glue and had no problems Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 2, 2014 Report Share Posted June 2, 2014 When I'd done a shit job cutting pads down I used some basic Araldite/epoxy resin stuff to help fill in any gaps and hold them in place, but for the most part superglue worked for me. 1 Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted June 2, 2014 Report Share Posted June 2, 2014 i used 99p shop super clue that doesnt even glue to metal or rubber.... it worked and has lasted me for atleast 8 months just fill the backing up as well as the gap that isnt meant to have glue it, that'll work Quote Link to comment Share on other sites More sharing options...
ItsMatt Posted June 2, 2014 Report Share Posted June 2, 2014 4 Quote Link to comment Share on other sites More sharing options...
ogre Posted June 2, 2014 Report Share Posted June 2, 2014 i had had no problems with that 2-1 in stuff where you mix two different tubes of stuff together can be a faf mixing it though.. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted June 2, 2014 Report Share Posted June 2, 2014 Less is more with super glue don't over do it. 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted June 2, 2014 Report Share Posted June 2, 2014 Got some shit from halfords that's good for hard plastics, would reccomend. Quote Link to comment Share on other sites More sharing options...
Culshaw95 Posted June 3, 2014 Author Report Share Posted June 3, 2014 Cheers for the help. I used Araldite/epoxy resin before but it always made my pads grubby as hell but then it can't be much worse than having the pads slowly coming out the backings Quote Link to comment Share on other sites More sharing options...
dann2707 Posted June 3, 2014 Report Share Posted June 3, 2014 I followed tnns guide that comes with backings and they suggest four variants of superglue they recommend all of loctite brand. Went and got that in the end as cheap superglue hasn't worked very well for me in the past. Quote Link to comment Share on other sites More sharing options...
