david509allen Posted May 26, 2014 Report Share Posted May 26, 2014 If anyone is wanting a cheaper alternative to magura blood. Get yaself down to a local motor factor and purchase some LHM+ fluid price varies from a fiver upwards Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted May 26, 2014 Report Share Posted May 26, 2014 or just use water? 1 Quote Link to comment Share on other sites More sharing options...
gale30jawa Posted May 26, 2014 Report Share Posted May 26, 2014 Or water 1 Quote Link to comment Share on other sites More sharing options...
dezmtber Posted May 26, 2014 Report Share Posted May 26, 2014 (edited) I quite like to use extra virgin olive oil, with a dash of chilli. helps make me feel younger Edited May 26, 2014 by dezmtber Quote Link to comment Share on other sites More sharing options...
Bint Posted May 26, 2014 Report Share Posted May 26, 2014 I use vodka Quote Link to comment Share on other sites More sharing options...
david509allen Posted May 26, 2014 Author Report Share Posted May 26, 2014 I know that lhm+ fluid is the same oil magura use only difference is that it does not have the blue or red dye in it and is a lot cheaper per litre Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted May 26, 2014 Report Share Posted May 26, 2014 http://www.epicbleedsolutions.com/products/brake-fluid/lhm-plus-mineral-oil/ There's a sentence on not using it on non dot fluid brakes. Quote Link to comment Share on other sites More sharing options...
lifes-a-trial Posted May 28, 2014 Report Share Posted May 28, 2014 There's a sentence on not using it in DOT fluid brakes Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted May 28, 2014 Report Share Posted May 28, 2014 Water + Antifreeze mix Quote Link to comment Share on other sites More sharing options...
Blake Posted May 28, 2014 Report Share Posted May 28, 2014 Thing is with minerel oil is there is no standard with it unlike dot fluid. So using lhm will void your warranty unlike royal blood. May as well use water haha. Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 28, 2014 Report Share Posted May 28, 2014 I know that lhm+ fluid is the same oil magura use only difference is that it does not have the blue or red dye in it and is a lot cheaper per litre LHM has higher viscosity than MRB resulting in stickier brake lever. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted May 28, 2014 Report Share Posted May 28, 2014 There's a sentence on not using it in DOT fluid brakesso my grammar was soooo poor you couldn't understand me? Dam, I'm must trying harderer Quote Link to comment Share on other sites More sharing options...
david509allen Posted June 7, 2014 Author Report Share Posted June 7, 2014 Dot fluid would kill magura hs33s. Ive seen online people usin lhm+ and thought y not its a lot cheaper and u get more bleeds. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted June 7, 2014 Report Share Posted June 7, 2014 I know. My link puts it across as lhm+ IS dot fluid Quote Link to comment Share on other sites More sharing options...
david509allen Posted June 12, 2014 Author Report Share Posted June 12, 2014 Fair play mate. I wont hold it against you. Even though ive had my ddg shooter for about 10 years plus got it when it was a week old in the shop for 280 quid im only now learning about the 2004 magura set up on it Quote Link to comment Share on other sites More sharing options...
