Neon Wing
Matthew_Gibson
Needed a few new bits frame, forks, freewheel. Got it build today. Bled the brakes. Riding really nice. will be having a proper ride on it later. so the bars will be adjusted, before anyone says anything! Just need to grind the rims!
FRAME - Neon Wing
FORKS - Neon Wing
BOTTOM BRACKET - Trials Tech Race
CRANKS - Echo TR 170mm
FREEWHEEL - Echo SL (brabd New)
REAR WHEEL - Echo Urban/Echo Hub - Schwalbe Fat Albert
FRONT WHEEL - Echo Urban/Onza Hub - Schwalbe Black Jack
STEM - Trials Tech 150 x 30
REAR BRAKE Magura HS-33 2005, 4 finger lever. Water bled. Trials Tech splitter. TNN Green in CNC'd backings. Echo TR Brake Clamps
FRONT BRAKE Magura HS-33 2004 2 finer lever. Water Bled. TNN Green in CNC'd backings, Echo TR Brake Clamps
CHAIN - KMC Z510 HX
SNAIL CAMS - Try all Smooth
10310090_10154195426060232_5436387819608
10325557_10154195426805232_6069002117193
10269461_10154195427005232_3145706231435
  • Like 4
I can't see any picture in the first post.
All works fine for me, think something is wrong at your end.
BIke looks nice, shame they didn't use an internal headset/headtube. That and your bars look ridonkulous!
Edited by craigjames
I think your handlebars might be back to front, other than that looks good!
Looks stunning Matt. You coming to Tartydays?
