Double Maggies or disc and Maggie
gale30jawa
Disc and Magura, but put Jitsie pads in the disc.
They make a disc feel as powerful and snappy as a Magura, but you get to enjoy the lush silence and modulation benefits of a disc.
It is a bit heavier, but not enough to be worth worrying about.
  • Like 2
NOOO juicy 3 hs11!!!!!
NOO
I was on this way too, but hs11 is faar from hs33 and juicy 3 is weak, evern for a beginner like me
if disc, then shimano Deore minimum. if you prefer a brake that is on and off, then magura hs33 all the way
This makes me excited as i've just ordered some! Wooo
I'm not normally the one to rave on about what set up I have atm and say it's the best thing since sliced bread then change my mind when I get something different but atm i'm running front disc and rear maggy and i'm genuinely in love. Apart from a bit of disc slipping it's all great. Not sure how I'd feel having to put twice as many rim grinds on, stopping everywhere with a honk killing pads etc.
Contaminate! Contaminate! Contaminate!
Yeah, fair point.
In terms of preference though, disc all the way. I don't manage to contaminate them enough for it to be a real concern for me, so that didn't even enter my mind :P
I'd have the same on the rear - potential contaminiation and all - if I could go longer than 5 minutes without bending a rear rotor :P
This, I always used to run dual maggie as I couldn't get a disc to work but running a 200mm rotor with Jitsie pads is unbelievable. Plus it means you can ride down hills!
EDIT: If you can't afford a Hope then try and source a 2nd hand Echo. Will be a lot cheaper and you can still use Jitsie pads.
shouldn't you try both and see what helps your riding the most? i find my confidence knowing how my discs behave lets me ride much better, i'd want that at a comp, and on the street...
gotcha, i presumed you were just swapping the set up on your yaabaa, the other bonus of discs is they make you appear smoother; the wheel/spoke flex can act as a compensator for minor f**k ups, and no magura noise makes it hard to work out what your doing with your brakes, giving the illusion of moar control.
  • Like 1
Long story I am breaking my mod! That had duel Maggies so I have 2 hs 33 and 1 hs11 Maggie to use! Plus I have found a front and rear hydrologic disc brake! But only the street bike has duel disc mounts! So I am trying to figure out what to do with them all now
Edited by gale30jawa
