Jonnie129129 Posted May 9, 2014 Report Share Posted May 9, 2014 (edited) Hi my freewheel always clicks when I pedal past the two o'clock position it clicks a few times and is really irritating and sounds like it's being trashed. What should I do?!?! It only happens when the pressure of my leg is applied Edited May 9, 2014 by Jonnie129129 Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted May 9, 2014 Report Share Posted May 9, 2014 It could be worn, but try cleaning it out before replacing it. Wd40, petrol bath somthing along those lines might help. Do you know which one it is? Quote Link to comment Share on other sites More sharing options...
Jonnie129129 Posted May 9, 2014 Author Report Share Posted May 9, 2014 It could be worn, but try cleaning it out before replacing it. Wd40, petrol bath somthing along those lines might help. Do you know which one it is? It's the standard one on the onza zoot Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted May 9, 2014 Report Share Posted May 9, 2014 probably worn out, or not worn in properly. ive got the exact same problem except the clicking is a loud snap haha Quote Link to comment Share on other sites More sharing options...
Jonnie129129 Posted May 9, 2014 Author Report Share Posted May 9, 2014 probably worn out, or not worn in properly. ive got the exact same problem except the clicking is a loud snap haha Mine is sometimes a loud snap what should I do Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted May 9, 2014 Report Share Posted May 9, 2014 It's skipping, happens all too often, give it a good clean out, if you use gt85 or wd40 to help you like said above, make sure that you lube it up after with some cycle oil or 3 in 1, gt and wd tend to dry things out over time :/ 1 Quote Link to comment Share on other sites More sharing options...
