SCOTTY___ Posted May 4, 2014 Report Share Posted May 4, 2014 Afternoon all. I have recently purchased some TNN adm refils. Installed as per the Instructions. Fresh grind using a 2.5mm metal cutting disc. Fresh bleed on the brake. Echo TR 24" Rear rim Rockman Radix frame - No booster. Now they just do not work. No honk, no bite or hold forward or rear. Next step is to clean the rim and pads with white spirits to see if anything has got on there (cant see how personally). Any help turning these pads on? The grind feels sharp/rough. Thanks in advance, Quote Link to comment Share on other sites More sharing options...
HippY Posted May 4, 2014 Report Share Posted May 4, 2014 Does the brake itself work? Like pistons move, clamps tight... Quote Link to comment Share on other sites More sharing options...
ogre Posted May 4, 2014 Report Share Posted May 4, 2014 keep your tyre on for the grind? was it a new disc? 1 Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted May 4, 2014 Author Report Share Posted May 4, 2014 New disc. Tyre on. Brake is set up square & all tight Quote Link to comment Share on other sites More sharing options...
ogre Posted May 4, 2014 Report Share Posted May 4, 2014 how much use you given it. i went back to magura, took 3-4 rides before the pads felt confidence inspiring.... Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted May 4, 2014 Author Report Share Posted May 4, 2014 They've worn down 2/3mm already with bedding in on the street. No serious rides. Expected them to work by now if im being honest Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted May 4, 2014 Report Share Posted May 4, 2014 is it a magura brake? Quote Link to comment Share on other sites More sharing options...
bing Posted May 4, 2014 Report Share Posted May 4, 2014 Mine took at least 4 good rides before they started working properly, FYI that was on a trialtech sl rim Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted May 4, 2014 Author Report Share Posted May 4, 2014 is it a magura brake? Yeh, 2011 vversion thats always worked perfectly Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted May 4, 2014 Report Share Posted May 4, 2014 Yeh, 2011 vversion thats always worked perfectly I had an echo brake a few years ago and the pistons only came out a certain amount, so on some rims it wasn't enough to fully clamp the rim. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted May 4, 2014 Author Report Share Posted May 4, 2014 The pads are set up square to the rim only 2mm away from the rim. The TPA is hardly on either. Quote Link to comment Share on other sites More sharing options...
Neon-trials Posted May 4, 2014 Report Share Posted May 4, 2014 Adms a crap mate change to cousts job done x Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 4, 2014 Report Share Posted May 4, 2014 Very odd. I'd say the rim is contaminated or the pads are dirty.Try re-grinding the rim, then rub it lightly with P240 paper or a wire brush, also rub the pads down ever so slightly using ~P400 paper. Make sure that the master cylinder isn't bottoming out although by the sound of things it isn't. I very recently went over from LGM's to ADM's and the brake performed poorly at first too but it has since become very powerful. Before this happened though I did end up grinding the rim again despite already having a fresh grind and did some work on the pad surface. Adms a crap mate change to cousts job done x And the prize for most useless post goes to.... 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 4, 2014 Report Share Posted May 4, 2014 once your grind starts to flatten down,cousts arent that good really,they always needed a fresh grind when i had them. Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted May 4, 2014 Report Share Posted May 4, 2014 once your grind starts to flatten down,cousts arent that good really,they always needed a fresh grind when i had them. cousts works absolutely shit for me (on an echo tr rim, magura brake) Adms a crap mate change to cousts job done x from what ive heard adms are shit. if it were me i would get some heatsink yellows best pads by far for me, i strongly recomend them Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 4, 2014 Report Share Posted May 4, 2014 get some trimps,theyre...my selfmade ones lol 1 Quote Link to comment Share on other sites More sharing options...
bing Posted May 4, 2014 Report Share Posted May 4, 2014 I've had all of the above. Cousts were best performing, but it massively depends on the rim. I had cousts and adms on the same rim, adms did perform slightly better on it. On my old tryall rim, cousts were boss Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 4, 2014 Report Share Posted May 4, 2014 My guess would be too harsh a grind, makes most pads work rubbish, wear down quickly and give the other characteristics you mentioned. You often get this witha brand new disc. Don't use white spirit, it'll pretty much leave oil on your rim! If you can, find a really old knackered cutting disc and just give the rim a tickle, should work much better. 1 Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted May 4, 2014 Report Share Posted May 4, 2014 To be honest I thought they'd be better than they are, but they still work well for me. Seconded on not using white spirit, its oil based and doesn't evaporate fully. Meths maybe? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 4, 2014 Report Share Posted May 4, 2014 I put a fresh pair on the other day and they are working incredibly well on my Echo rim :/ Maybe you've got a bad batch? Quote Link to comment Share on other sites More sharing options...
niconj Posted May 4, 2014 Report Share Posted May 4, 2014 (edited) if it were me i would get some heatsink yellows best pads by far for me, i strongly recomend them Went from bedded in Heatsinks to Trialtech Sport* w/o regrinding the rim. The latter outperformed the Heatsinks even w/o bedding in. *Both glued into TNN backings Edited May 4, 2014 by niconj Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 4, 2014 Report Share Posted May 4, 2014 (edited) Went from bedded in Heatsinks to Trialtech Sport* w/o regrinding the rim. The latter outperformed the Heatsinks even w/o bedding in. *Both glued into TNN backings There's not point turning this into a which pad is better option as it's not going to help Craig dude Edited May 4, 2014 by dann2707 Quote Link to comment Share on other sites More sharing options...
niconj Posted May 4, 2014 Report Share Posted May 4, 2014 There's not point turning this into a which pad is better option as it's not going to help Craig dude Since Adam has already provided the solution... Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 4, 2014 Report Share Posted May 4, 2014 Since Adam has already provided the solution... Who's to say it's definitely going to solve his problem? Think outside the box you berk. What clamps are you using Craig? 2 Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted May 4, 2014 Report Share Posted May 4, 2014 Berk 1 Quote Link to comment Share on other sites More sharing options...
