callum199922 Posted April 24, 2014 Report Share Posted April 24, 2014 I have an inspired element 2013 and the back brake is very mushy as I say and much harder to pullthen the front and II think it it's because of the rubber spacers that stop the cable scratching the frame so I was wondering how could I take them off and not have my cable scratch up the frame. Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 24, 2014 Report Share Posted April 24, 2014 It's nothing to do with those trust me. If the brake feels spongey then either the pads aren't hitting the rim squarely or the cable is stretching. First make sure the pads are set right and if that doesn't sort it try getting a linear slic brake cable. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 25, 2014 Report Share Posted April 25, 2014 You could heatshrink the exposed bit, or pull an inner out of an old outer casing... but I'd agree with foxy that those won't be the problem. Unless they're cartoon sized Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted May 1, 2014 Report Share Posted May 1, 2014 A linear cable will help, also make sure the pads are square too. Quote Link to comment Share on other sites More sharing options...
