*gentlydoesit Posted April 23, 2014 Report Share Posted April 23, 2014 Title says it all really, I think the answer is going to be a big fat no, but just incase I'm wrong.. Cheers Quote Link to comment Share on other sites More sharing options...
dezmtber Posted April 23, 2014 Report Share Posted April 23, 2014 A disc hose will fit if you use say hope or goodridge kits, but i don't know if the hose material for dot fluid works with mineral oil though i cant see why not. Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted April 24, 2014 Report Share Posted April 24, 2014 no, you need proper magura stuff because it is not a standard size, so if you are using the incorrect hose it will make your bake feel rubish Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 24, 2014 Author Report Share Posted April 24, 2014 Internal sizes are differnt then? I thought they may be Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 24, 2014 Report Share Posted April 24, 2014 What *exactly* are you trying to do? Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 24, 2014 Author Report Share Posted April 24, 2014 Use a disk brake hose on a rim brake Fancy a colour change is all Quote Link to comment Share on other sites More sharing options...
SteveCook Posted April 24, 2014 Report Share Posted April 24, 2014 I wouldn't recommend it but it could work Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 24, 2014 Report Share Posted April 24, 2014 Use a disk brake hose on a rim brake Fancy a colour change is all Think Ads means what hose and what brake exactly Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 24, 2014 Author Report Share Posted April 24, 2014 (edited) Ahh... ebay generic coloured disk brake hose on echo rim brakes, all barbs, no shrouds. Thought all the disk hoses would be the same? Edited April 24, 2014 by *gentlydoesit Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 24, 2014 Report Share Posted April 24, 2014 Using barbed fittings would be fine as there's no worries about leaks though the bore size of the hose will affect how good the brake is. I was going to get some of the Unex braided hose for mine years ago but was put off it as I got told it was smaller than standard magura hose which means the fluid can't travel through as quickly and so it makes the brakes feel sluggish. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 25, 2014 Author Report Share Posted April 25, 2014 Expected that would be the case, cheers. Quote Link to comment Share on other sites More sharing options...
Willeyeam Posted April 25, 2014 Report Share Posted April 25, 2014 I have a friend who bought a generic disc hose from a lbs for his magura. Despite repeated bleeding it feels terrible and has barely any power. Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted April 25, 2014 Report Share Posted April 25, 2014 Using barbed fittings would be fine as there's no worries about leaks though the bore size of the hose will affect how good the brake is. I was going to get some of the Unex braided hose for mine years ago but was put off it as I got told it was smaller than standard magura hose which means the fluid can't travel through as quickly and so it makes the brakes feel sluggish. I used the those Unex hoses for aaaaaaages and my brakes felt fine. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 25, 2014 Report Share Posted April 25, 2014 No really, they didn't If you're trying to use barbed fittings with hose made for disc brakes, it won't work (safely). If you are buying all the relevant fittings to attach said hose to the brake properly then it will work, but be expensive and the brake will feel sluggish. If you desperately want coloured hoses, Google heatshrink. 1 Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 25, 2014 Report Share Posted April 25, 2014 I'm running a rear magura with a shimano disc hose and I haven't had any problems Quote Link to comment Share on other sites More sharing options...
Buzzbox Posted May 10, 2014 Report Share Posted May 10, 2014 My local bike shop fitted my HS33 with a disk hose recently. I've had nothing but problems with it, It just gulps in air from nowhere! I'd stick with standard hoses if i were you. Quote Link to comment Share on other sites More sharing options...
James281098 Posted May 11, 2014 Report Share Posted May 11, 2014 If you just want to change the colour, buy some insulation coloured tape and get a long trip and put it over the cable, it looks the same as a coloured cable if you do it right Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 16, 2014 Report Share Posted May 16, 2014 My local bike shop fitted my HS33 with a disk hose recently. I've had nothing but problems with it, It just gulps in air from nowhere! I'd stick with standard hoses if i were you. Did you ask them to use a disc hose? If not i'd take it back and tell them to change it for a proper magura hose. Quote Link to comment Share on other sites More sharing options...
