peggysue Posted April 23, 2014 Report Share Posted April 23, 2014 Need to get one back in the cable, any tricks to help get them in easy? I have a vice but no magura blocks and I know what a pain they can be sometimes. Quote Link to comment Share on other sites More sharing options...
forteh Posted April 23, 2014 Report Share Posted April 23, 2014 Make some blocks from a piece of wood, makes it a whole lot easier Quote Link to comment Share on other sites More sharing options...
bing Posted April 23, 2014 Report Share Posted April 23, 2014 And put an old spoke through the hole with the nipple still attached, and hammer it in that way, miles easier Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 23, 2014 Report Share Posted April 23, 2014 The only tip I know is using a bit of spoke with a nipple screwed on the end to thread through the barb and into the hose to help it go in straight but you still need the magura blocks or some bits of wood to clamp the hose and hold it steady. Multi snaked Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 23, 2014 Report Share Posted April 23, 2014 I used a flare block for car brake lines, it worked sooo well Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 23, 2014 Report Share Posted April 23, 2014 Block of wood, drill a hole in it thats smaller in dia than the black hose. Then cut that little bitch right in half. Place hose in the wood and vice it. Tap away. Quote Link to comment Share on other sites More sharing options...
