Cheap(ish) street disc brakes
HippY
a very last quick question
I will order Deore M615 and I need a new adapter.I have a 0 IS Frame mount, so a QM10 maggie ( link ) or a Formula ( link ) would be a good choice? which one would be the best?
Would it worth to spare £15 more for an M675 ?
Edited by UKHippY
Get a deore. I ran one for ages on many different bikes and it was epic. Bit of pad wobble but absolutely no complaints about power, bite and hold. Nearly as good as a saint with the right rotor
  • Like 1
what does the pad wobble means?
Is it like on maggies, so just incredibly noisy, or you feel the lever wobbling as well( like if you use a wobbly disc, and it pulses, if it makes sense) ?
The best budget disk are Deore if you ask me. Like Ali said, you get a but of pad wobble but it didn't bother me too much. I took mine straight off my hybrid and put it on my stock with the Avid 180 rotor that was on already and it was amazing from the off.
I don't have pad wobble as such now that I adjusted the lever, and no they are silent! Stealth like :P
I don't understand how adjusting your lever affected the pad wobble. Fair enough if it did like but I thought pad wobble was caused by the pads having room to move in the caliper.
  • 3 weeks later...
little bump here as well
After I bend the front disc, I came to the relisation that I should get a new front system
I checked my budget, and it is around £75, £100 would be reeeeally tops
so
i need a disc and brake
Disc: RT66 or supplied with the brake
Brake choices:
Deore +RT66 at the rear it is surprisingly good and very very cheap
SLX M675+RT66: Good power, and I am really happy with Shimano in general
MT2+Storm rotor: I love the magura brakes feeling and with `14 HS33 I had good experiences
Avid Elixir 5= the Skye is equiped with it, it should not be that bad then
So I would go Deore minimum, but little bit more power and sharpness would come handier. Does it worth to upgrade, or a Deore should be fine for few rides per week and with small progressing?
For that money you could probably get a decent pair of Hopes or at the least get a front one and some Jitsie pads
used ones?
I do not want to go with hopes, unless they are easy to service(=eg, a guy who is completely retard with brakes) and good condition I would consider them as an option, but new brakes gets my priority
Seriously? I got a pair of Tech Trials (minus discs) for £100 before xmas and a Trial Zone which just needed a bleed for £30. If you're concerned about servicing then send them to Tarty or get whoever you buy one off to send it them first if it really needs it.
You'll get a better quality brake and will be saving money (and possibly teeth) in the long run.
so a Hope TrialZone/ Tech trial used with Jitsie pads is that better than a MT2/SLX?
I heard very very good things about Jitsie pads (HS33 like hold and bite)
The reason why I dont/did not want to go with them is they are expensive new and I do not really trust with used brakes. but it should be fine, if I can send them to tarty to sort them out, I fire up a wanted thread
about Zee: I am not sure if I would need it seeing as the £35 Deore is perfect for me on the rear. i am not a good rider and sadly I do not even progress quickly, so I think I might not need too expensive brakes, if that makes sense
Edited by HippY
Nope it doesn't make sense, basically you're saying that as you aren't a very good rider you don't need a brake which you can rely on?
Also, I sold my MT2 to fit a used Trial Zone with Jitsie pads and it's the best disc brake I've owned so far
no, basically I am saying that I am not a good rider, an SLX might be waay overpowered for me, and I am not sure if there would be a difference between the Zee
I do not know much thing about disc brakes, all I know, that Deore is good for me on the rear and I do not progress and dont ride too often.
No more question asked then :)
Edited by HippY
I am aware, that 4 pot huge power, but would i feel it use it?
Here I am not worried about the brakes, but about myself, as a casual rider I do not want to spend too much money on my bike, whereas I would not buy a serous gaming pc if I would play causal games
To be honest, if you compare, ceteris paribus, a BR-M785 (which has the same stoping power as the BR-M675) with a BR-M640, the difference is only 8.2% in favor of the Zee.
In comparison, the difference between a 160 and a 180 rotor, using a BR-M785 is 13%.
Edited by niconj
Personally I think a powerful reliable brake is important no matter what level of rider you are (as long as you don't ride brakeless). I had more accidents due to dodgy brakes as a beginner because when they failed I couldn't control the fall as well as I do now.
  • Like 1
that is the reason why I want to buy a decent New brake (retard friendly bolt on) as I want no dodgyness
I am just debating what would be too much for me.
Biking is my second hobby and I want something stable and realiable. it might not have the highest end equipment, that are suited to the good riders, but I am not a good rider either
