Dazza1414 Posted April 17, 2014 Report Share Posted April 17, 2014 (edited) Hi everybody, I've got a hope mono trial front brake and not long ago I fitted new pads, I rode it for a bit and they seemed to be pretty good. The bike has now been sat unused for a while and I went to move it today and noticed the front brake has developed a sqealling noise. Can anybody explain why this is and suggest a way I can sort the issue. cheers Daz Edited April 17, 2014 by Dazza1414 Quote Link to comment Share on other sites More sharing options...
dezmtber Posted April 17, 2014 Report Share Posted April 17, 2014 Does it still have the same power? mine sqeak from time to time without loss of power. if its a really loud honk with no power its possibly oil on the pads/rotor or glazed pads/rotor issues Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 17, 2014 Author Report Share Posted April 17, 2014 I'm still bedding the pads in so it's not at full power. The squeal only occurs really when I push it forward or roll slowly, doesn't really make a noise when under load. Quote Link to comment Share on other sites More sharing options...
dngr2self Posted April 17, 2014 Report Share Posted April 17, 2014 It could be be just the pads rubbing slightly. Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 17, 2014 Author Report Share Posted April 17, 2014 just seemed a bit strange that it was all set up fine and after being sat it's started to make a noise Quote Link to comment Share on other sites More sharing options...
dngr2self Posted April 17, 2014 Report Share Posted April 17, 2014 Have you taken the wheel out since you last used it? Quote Link to comment Share on other sites More sharing options...
dezmtber Posted April 18, 2014 Report Share Posted April 18, 2014 Is one of the pads draging or are both the the pads touching the rotor when the brake is off Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 18, 2014 Author Report Share Posted April 18, 2014 Is one of the pads draging or are both the the pads touching the rotor when the brake is off Is it worth taking out the wheel and pushing the pads back? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted April 18, 2014 Report Share Posted April 18, 2014 (edited) Meh, maybe. Best bet would be to go out with a scooshy sports water bottle with cold water. Go around dabbing the brake pads on and off for a while till they heat up then spray some water on to cool them down.. DO this a few times and the pads should be bedded in. I used to hold the lever in continuously and drag slightly to bed in but that seemed to glaze the pads too much Edited April 18, 2014 by Ross McArthur 1 Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 18, 2014 Author Report Share Posted April 18, 2014 Meh, maybe. Best bet would be to go out with a scooshy sports water bottle with cold water. Go around dabbing the brake pads on and off for a while till they heat up then spray some water on to cool them down.. DO this a few times and the pads should be bedded in. I used to hold the lever in continuously and drag slightly to bed in but that seemed to glaze the pads too much So if I literally ride round tapping the brake on and off that will be enough to heat it up enough? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted April 18, 2014 Report Share Posted April 18, 2014 http://www.youtube.com/watch?v=5julb5Fg51w 1 Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 18, 2014 Author Report Share Posted April 18, 2014 http://www.youtube.com/watch?v=5julb5Fg51w Haha, nicely answered. You seem quite knowledgable Ross, if you don't mind can I pm you about another question so not to go off topic? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted April 18, 2014 Report Share Posted April 18, 2014 Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted April 18, 2014 Report Share Posted April 18, 2014 If you're feeling brave daz. He seems to be on a good day so worth a shot. Can always calm him down if he gets fired up with some bucky. Quote Link to comment Share on other sites More sharing options...
Dazza1414 Posted April 18, 2014 Author Report Share Posted April 18, 2014 Ross was very helpful. Top bloke! Quote Link to comment Share on other sites More sharing options...
