Jeromboii Posted April 14, 2014 Report Share Posted April 14, 2014 Currently running only a rear maggy on my mod . I have just returned to trials after a year and a half. When I side hop I seem to be placing front wheel on the object stright away and then rear wheel follows. The rear wheel is like out of control and it dosnt look smooth nor dose it feel right . Anyone give me pointers on how to sort it ? Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted April 14, 2014 Report Share Posted April 14, 2014 Start further away from the wall. Preload more and explode upwards slightly angled towards the object in question. Film yourself doing it and compare it to someone who can do them well.. Quote Link to comment Share on other sites More sharing options...
Jeromboii Posted April 14, 2014 Author Report Share Posted April 14, 2014 Yeah I have filmed myself doing it . The rear tyre seems to go miles higher than the wall, so I thought doig higher stuff would improve it but it dosnt . Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted April 14, 2014 Report Share Posted April 14, 2014 Ride with Scott for a while. He will set you right. Quote Link to comment Share on other sites More sharing options...
inthesystem Posted April 14, 2014 Report Share Posted April 14, 2014 Currently running only a rear maggy on my mod . I have just returned to trials after a year and a half. When I side hop I seem to be placing front wheel on the object stright away and then rear wheel follows. The rear wheel is like out of control and it dosnt look smooth nor dose it feel right . Anyone give me pointers on how to sort it ? i see ALOT of people doing this, i find its a really simple thing to fix, as you preload lean BACKWARDS not forwards, as in, imagine your torso when your on the ascent upwards, it want to be vertical, not in any way leaning forward over the front, and also the arms, they dont want to be going forwards with a slightly flared wrist, they want to be going upwards diagnoly, its just a matter of trying to land over the centre and not puching the front wheel into it, try watching TRA sidehop, he does it similar to myself. 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted April 14, 2014 Report Share Posted April 14, 2014 I always land with arms bent but it seems arms straight is the way to go. Sidehops seem to be the most impossible thing for kicking bad habits if that makes sense 1 Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 14, 2014 Report Share Posted April 14, 2014 (edited) Also, make sure you do them the "right way" (strongest foot away from the wall) or you will get moaned at by George Edited April 14, 2014 by AkuskaUK Quote Link to comment Share on other sites More sharing options...
Jeromboii Posted April 15, 2014 Author Report Share Posted April 15, 2014 Thanks for the help guys ! I'll have a try again today ! Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted April 15, 2014 Report Share Posted April 15, 2014 Also, make sure you do them the "right way" (strongest foot away from the wall) or you will get moaned at by George does that make a differnce? I naturally do it the other way.. failing mostly. Is there a right and wrong way? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 15, 2014 Report Share Posted April 15, 2014 Yeah there is technically but a few top rides do it the other way, French rider on inpulse I think does it? (can't spell his name, don't wana offend) But my mate was doing it the 'wrong' way and told him to swap he's now getting 40" as opposed to around 35" the wrong way. It seems like you normally hit a peak doing it the wrong way Quote Link to comment Share on other sites More sharing options...
Blake Posted April 15, 2014 Report Share Posted April 15, 2014 I think when you do it the right way if you don't make the sidehop you can land on your crank/bad foot a lot easier as opposed to just stacking it. Which makes it much less scary to do bigger walls/push your limits. Also doing it the wrong way looks terrible in my opinion even when it's a huge wall. It's good to be able to do it both ways but I do think you should be a bit better to your good side. Also if you imagine you're doing a gap after you've done a sidehop to rear, if you do it to the wrong way then you're f**ked as you have to turn like 90 degrees to get into your gap position. I used to do it the wrong was and was pretty shit at it, struggling to get 35ish and almost made a 40 once. Started doing it the proper way and was getting 42" in a few weeks so I'd deffo say try and sort it out. Quote Link to comment Share on other sites More sharing options...
Lord Banks Posted April 16, 2014 Report Share Posted April 16, 2014 You should really learn both ways if you ride natural though, sometimes you don't have a choice which side you have to do it. Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 18, 2014 Report Share Posted April 18, 2014 (edited) Edited April 18, 2014 by AkuskaUK Quote Link to comment Share on other sites More sharing options...
Jeromboii Posted April 21, 2014 Author Report Share Posted April 21, 2014 When landing , frount wheel first then rear follows ? Or land both wheels at same time ? Quote Link to comment Share on other sites More sharing options...
