Ffw oscillation
*gentlydoesit
Thank fook.
What's the reason? it seems the thread on the crank isnt parallel with the axle.
Some may say rubbing your testicles on each freewheel tooth at when the clock strikes midnight on the 16th of May solves this issue.
p.s yes
I've started early, is that ok :)
It's because the the theoretical axis of the inner track / raceway is slightly out of alignment with the mounting thread (and probably outer track / raceway - OD. alignment). So basically yes - shit tolerances. Although it shouldn't affect the performance as long as the two tracks are round, concentric and do not have too much run out.
