dann2707 Posted April 6, 2014 Report Share Posted April 6, 2014 Okay so what has happened? I've topped up my brake and now the TPA is wound compaltrely off and now i have a bit of nipple sticking out either side (Don't mind the occasional nipple slip but this is just on another level) And I can puysh one pad and it flies out the other side oh my god? What happened? Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 6, 2014 Report Share Posted April 6, 2014 Did you syringe bleed? Sounds like the fluid had nowhere to go so it went through the pistons in the slaves. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 6, 2014 Author Report Share Posted April 6, 2014 I've just fixed it now!! Weirdly enough, At the master end, when i've nipped the grub screw up - It looks like the water in that hole where the threaded section is has been forced into the system when nipping up the grubby. I loosened the grub screw off a tad bit, a bit of water fired out and nearly landed on me, tightened it up again and it's all dandy woo Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 6, 2014 Report Share Posted April 6, 2014 Thought that was the case, nice one. Quote Link to comment Share on other sites More sharing options...
Blake Posted April 7, 2014 Report Share Posted April 7, 2014 Ant used to do this on purpose all the time Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 7, 2014 Author Report Share Posted April 7, 2014 Why? Quote Link to comment Share on other sites More sharing options...
Blake Posted April 7, 2014 Report Share Posted April 7, 2014 Dunno got his pads closer to the rim Also because we always had Leakey brakes it made them last longer Quote Link to comment Share on other sites More sharing options...
