Ille Posted April 6, 2014 Report Share Posted April 6, 2014 (edited) Hi guys) I'm from Ukraine, and now represent a new bike for training. Frame and Fork - Frame: Echo Pure 2011 - Fork: Bonz 2014Wheels - Front hub: Echo - Rear hub: Zhi L - Front rim: Neon 26" - Rear rim: Try-All K2 - Spokes: - Front: Sapim Laser - Rear: Sapim Race - Inner tube: MAXXIS Ultralight 26X1.90/2.125 - Inner tube: MAXXIS Ultralight 26X1.90/2.125 - Front tyre: Try-All Shift 26 x 2.0" - Rear tyre: Try-All Stiky Lite 26 x 2.5" Brakes - Front brake: Magura HS33 2011 (Long lever blade) - Rear brake: Magura HS33 2011 (Long lever blade) - Brake clamps: Echo - Brake Pads: - Front: Michel Coustellier - Rear: Heatsink CNC Coustsink Drivetrain - Cranks: Try-All CNC ISIS, 175mm - Freewheel: Echo SL 09, 108.9, 18t - Chain: YABAN MK747 - Rear Sprocket: Zhi 15t - Pedals: Try-All Single Cage Elite 7075 - Bottom bracket: Echo Urban ISIS - Bashring: Viz, BlackSteering - Headset: Echo SL - Stem: Try-All 3D Forged, 150mm x 30° - Grips: BBB - Handlebars: Try-All Carbon Weight - 8.50kg Geometry - Wheelbase: 1080mm - Chainstay: 380mm - BB Height: +55mm Edited April 6, 2014 by Ille Quote Link to comment Share on other sites More sharing options...
HippY Posted April 6, 2014 Report Share Posted April 6, 2014 I love the pink frame, it is soo horrible that it looks good Is not 18/15 gear ratio too low, or is it a good ratio for comps? Quote Link to comment Share on other sites More sharing options...
Lotus Lu Posted April 6, 2014 Report Share Posted April 6, 2014 Why are you using so many steel bolts and such heavy cranks but drilling holes on the frame? The holes will kill the frame. Quote Link to comment Share on other sites More sharing options...
bing Posted April 6, 2014 Report Share Posted April 6, 2014 Not sure drilling loads of holes in an echo frame is a good idea Quote Link to comment Share on other sites More sharing options...
craigjames Posted April 6, 2014 Report Share Posted April 6, 2014 Was more thinking why have such a heavy BB, i know drilling holes is free; but a Ti BB will save more weight and will definitely cost less than a new frame when this dies in the not too distant future. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 6, 2014 Report Share Posted April 6, 2014 Dafuq is that bracing in between the top and down tube?! 1 Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted April 6, 2014 Report Share Posted April 6, 2014 I think the whole look unreal. Quote Link to comment Share on other sites More sharing options...
shercofray Posted April 6, 2014 Report Share Posted April 6, 2014 I think the whole look unreal. That good English is. 5 Quote Link to comment Share on other sites More sharing options...
Blake Posted April 6, 2014 Report Share Posted April 6, 2014 (edited) why is the geo f**ked up too? EDIT: ah it's not a 24 :l Edited April 6, 2014 by DrStix Quote Link to comment Share on other sites More sharing options...
Ille Posted April 6, 2014 Author Report Share Posted April 6, 2014 Thank you all for the comments. Interesting to read your comments about the bike. Holes in the frame - not see anything wrong! A broken frame or not shall see. About BB, cranks and steel Bolts and other details - this is not the end Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 6, 2014 Report Share Posted April 6, 2014 I can see into the future. 1 Quote Link to comment Share on other sites More sharing options...
stirlingpowers Posted April 6, 2014 Report Share Posted April 6, 2014 (edited) Worldcup elite rider David Hoffmann put many holes into the legs of two Trialtech 26 forks. After many months (which is a long time for his massive riding) they cracked nowhere near the holes. The only thing which worries me here are the holes on the lower end of the steering tube and on the downtube reinforcement plate. But hey, if it holds, it will advance frame building. Edited May 19, 2014 by stirlingpowers Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 6, 2014 Report Share Posted April 6, 2014 Is not 18/15 gear ratio too low, or is it a good ratio for comps? That's pretty much standard for a trialsy 26" bike 1 Quote Link to comment Share on other sites More sharing options...
craigjames Posted April 6, 2014 Report Share Posted April 6, 2014 The only thing which worries me here are the holes on the lower end of the steering tube and on the downtube reinforcement plate. But hey, if it holds, it will advance frame building. Don't think it will, I would go as far as to say that 99% of bike manufacturers know that there are better ways to lose weight from a frame than simply drilling holes in it. With respect to Hoffman's forks, that's just asking for trouble. Forks are one of the most commonly broken components, would you want to turn yours into a glorified aero bar?! An even stranger thing to do considering he's riding a hoffman frame, not really known for being exactly lightweight. Quote Link to comment Share on other sites More sharing options...
stirlingpowers Posted April 6, 2014 Report Share Posted April 6, 2014 Team frames are 100% custom, so weights are largely unknown. Forks break at certain places, and he breaks them all the time, so he probably knows the weak points resulting from his riding. Quote Link to comment Share on other sites More sharing options...
craigjames Posted April 6, 2014 Report Share Posted April 6, 2014 Forks crack/snap at break mounts and steerer/crown points because they are high stress areas. Just because they break there in a normal fork doesn't mean that they won't break somewhere else if you start drilling holes in them! Quote Link to comment Share on other sites More sharing options...
Lord Banks Posted April 7, 2014 Report Share Posted April 7, 2014 Drilling holes is a bit dodgy, when the bike takes a ‘shock’, the energy reverberates and gets absorbed into the metal, with holes everywhere, that energy travels further and for longer and gets into the joins and weld areas easier. Quote Link to comment Share on other sites More sharing options...
Ille Posted April 7, 2014 Author Report Share Posted April 7, 2014 Guys dont worry. Bike is not built more for light weight, but for me - beautiful and stylish. Drilling in the frame - I dont think that something will happen soon. But time will tell. Quote Link to comment Share on other sites More sharing options...
