Frame help
trialsiain
Stuck between two frames and need to decide so i can build a bike up before Sheffield on the 30th
Looking at either a
Limey 4 - Wheelbase: 1090mm
Chainstay Length: 380mm
BB Rise: 70mm
Head Angle: 72°
Centre of BB shell to top centre of head tube: 650mm
Gu - Wheelbase: 1095mm
Chainstay Length: 380mm (18:15 gear ratio with no half link)
BB Rise: 70mm
Head Angle: 71 degrees
Centre of BB shell to top centre of head tube: 660mm
Cant decide. Love the style/ colour of the GU but like the limey because it has integrated booster/ internal headtube etc..
Edited by trialsiain
I would go for the gu cause of the head angle :)
should be easier doing front to rear's, other than that all other measurements are almost the same
Wont it make it harder if your not as "over the front" ?
Run carbon forks with the GU and the geo will be pretty much the same as the Limey.
still a cm difference in reach though, Is that a noticeable amount ?
I'm unsure about reach to be honest, I'm only really clued up on wheel base and BB height. I can't imagine it making much or a difference though.
Saying that, speak to Jack Harmer or James Bancroft, they have both ridden both bikes in question, and i know Jack said he preferred the GU to the Limey.
I cant imagine you have any trouble with either in that case. I'm around 5'8 and find Andrei's GU a little long for me but get on alright with Seddon's Limey 4
Mind you, Joe's about the same height as me so it's set up similar to my height
